Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
Identify Air Compressor
this thread has 9 replies and has been viewed 1210 times
Old 03-08-2018, 01:01:43 AM
KenH KenH is offline
Default Identify Air Compressor
Can anyone help me identify this air compressor , has no tag or numbers on it. Had a 10 hp 3 phase motor when I got it. Any info would be helpful .
Old 03-08-2018, 01:05:31 AM
cobbadog cobbadog is offline
Default Re: Air compressor
Hi Ken, what info is on the tag facing the front on the RH side of the tank?
Old 03-08-2018, 01:14:56 AM
It’s the Welding shop that made the tank
Old 03-08-2018, 01:26:20 AM
Here is tag on tank
Old 03-08-2018, 10:23:02 AM
dkamp dkamp is online now
eMail NOT Working
Default Re: Air Compressor
I'd start by looking at it really close... look at the end plates, crankcase, oil filler and sight glass, cylinder shape, cylinder head, and valve boxes, then through photos of antique air compressors. Speedaire, Brunner, Quincy, Champion... evenutally you'll see a cylinder head that looks like yours, then search deeper.
Compressor manufacturers tended to use cylinder and head designs that were modular... a single cylinder compressor could be made into a multi by casting a new case, forging a new crank... or a two-stage by making a different crank and rod for shorter stroke on the HP stage... or smaller bore on the HP stage... but they looked the same. Once you've narrowed it down, details will typically tell you the rest.
Old 03-09-2018, 09:58:30 AM
s100 s100 is offline
That's not like any compressor I have ever seen before, and I have seen quite a few although most I have paid attention to were much older than that one. Several makers had dual stage V twins including Westinghouse and Worthington but again those were much older than yours and if memory serves all of those had disc valves except the I-R type 30 which looked nothing like yours.
Once they got to that size most companies that made vee type compressors had four cylinder models, for the reason alluded to by Dkamp, the ability to recycle smaller cylinders pistons heads etc.
Are the fasteners on that thing metric or conventional? It may be an import. Although going by the date on the tank some US manufacturers might have made the change by then.
Old 03-09-2018, 03:11:33 PM
Looks similar to an Ingersol-Rand my fire department has for the alarm horns. Ours dates back to the 1940s
Old 03-09-2018, 07:26:35 PM
Default Re: Identify Air Compressor
thank you to all that have posted. Figure i would find the one that no one has a definite clue where it came from, love a good challenge. thankfully it runs perfect and makes air very quickly. would like to up grade motor, it looks like mice used it for a home at some time , i replaced a lot of the chewed up wires. so many projects and so little time .
Old 03-09-2018, 09:08:28 PM
Gentlemen we have a winner , my compressor is a Schulz MSV 40, 37.5 cfpm
I've included their link if anyone else should have the same delima. you get a chance check out their sight they may a 5 cylinder looking thing , looks like old rotary air plane engine !! once again thanks for everyone's help.
http://www.schulzamerica.com/
The Following 3 Users Say Thank You to KenH For This Post:
Old 03-09-2018, 09:16:56 PM
Yup, I thought that thing had a furrin look about it. But my first guess would have been Italian or maybe Spanish. And yet it is... Brazilian! Interesting. Thanks for posting what you found. It's always good to have a puzzle solved.
Help needed to identify an Air Compressor Andyt001 Unidentified Engines 2 06-22-2012 05:19:53 AM
Leo compressor: Trying to identify a small compressor unit MattFretwell Unidentified Engines 1 02-27-2012 07:01:50 PM
Please help identify this compressor... allgattill Small Air Cooled Gasoline Engines 4 04-19-2011 09:09:13 PM
Help Me Identify this compressor! PhillyM38 Antique Engine Photos 1 06-13-2008 11:05:33 PM
Help Me Identify this compressor! PhillyM38 Farm Antiques and Collectibles 0 06-11-2008 02:03:50 PM
