Welding Shop
Cincinnati Lead Screw Repair
this thread has 3 replies and has been viewed 1045 times
Old 04-27-2018, 12:40:35 PM
restore49 restore49 is offline
Default Cincinnati Lead Screw Repair
Built new nuts and would like to flip screw 1 1/8 not hardened and use the Not worn chipped end. Was thinking cut flip drill 1/4" pilot holes bevel and continuous mig weld??
ID:	309241   Click image for larger version
ID:	309242   Click image for larger version
Old 04-27-2018, 02:22:20 PM
Default Re: Cincinnati lead screw repair
Main problem is going to be accurate alignment of course. Especially with those unequal diameters. Simple v-block alignment wouldn't work. I'd suggest you go deep on your pilot holes and use O1 drill rod slugs for alignment, or even thread and use all-thread. Do multiple opposing tacks before long welds. Maybe constuct alignment jigs for each end. Another problem is likely to be you will lose your lathe while working on it, unless you have multiple lathes...
Doc
Old 05-01-2018, 12:21:15 PM
Default Re: Cincinnati Lead Screw Repair
Success - pin 1/4 center - bevel 45 - clamp sides two fixtures - tack weld(more like root pass) - continuous weld. .080 deflection - spot heat cool method , with help from pipe weight hang out on end - now .002 Total.
Old 05-01-2018, 12:25:10 PM
Thanks Thaumaturge:
Used a twin friends machine to finish turning.
Name:	Finished lead screw.JPG
The Following User Says Thank You to restore49 For This Post:
Sheet Metal Repair - Lead Rod - Casting - Mold Paul Spence Hit & Miss Gas Engine Discussion 15 01-15-2018 03:21:57 PM
Buda Railroad Bottle Jack Ratchet/Screw type - Repair trafficagent Machine Shop and Tool Talk 3 01-06-2014 06:10:04 PM
Cincinnati mill shakeyjake36 Machine Shop and Tool Talk 3 04-03-2013 11:01:45 PM
10 lead to 12 lead, bringing out the other leads Birken Vogt Generators & Electric Motors General Discussion 1 03-23-2013 03:27:18 PM
Square Thread Lead Screw Nut or Tap? Rex Piekarczyk Machine Shop and Tool Talk 22 02-03-2010 12:22:27 PM
