Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
1947 Nat'l BD Quincy/Wisconsin S# 259 compressor info needed.
this thread has 22 replies and has been viewed 893 times
Old 04-13-2019, 02:01:07 AM
Vanman Vanman is offline
Default Re: 1947 Nat'l BD Quincy/Wisconsin S# 259 compressor info needed.
I don't recall if it's been mentioned, but have you hydro-tested your tank?
Old 04-13-2019, 02:36:52 AM
Lizardking Lizardking is offline
I did a visual and a leak test with my pressure washer after sanding and wire wheel . The tank is about 1/4 inch think! I'll be running it at 90 psi most of the time.
The Following User Says Thank You to Lizardking For This Post:
  #23
Old 04-18-2019, 05:49:16 AM
Here's a few pictures of the hydrostatic testing I did on my 1947 tank. Held 300 psi for 24 hrs and hit the tank with a rubber mallet with no issues.
ID:	332917   Click image for larger version
ID:	332918   Click image for larger version
ID:	332919   Click image for larger version
The Following 2 Users Say Thank You to Lizardking For This Post:
Quincy Compressor dirtycurt Machine Shop and Tool Talk 2 08-23-2016 05:39:47 PM
19?? Quincy Engine Ex air compressor. JohnAW Antique Engine Photos 3 09-17-2015 08:49:04 PM
I need a manual for a 210 quincy compressor badmechanic Small Air Cooled Gasoline Engines 0 07-01-2012 11:58:31 AM
Roths Industries Garden King Model W 1947/48 (info needed) Jeff in PA Garden Tractors and Mowers 20 06-24-2010 05:00:49 PM
Wisconsin / Quincy Air Compressor TomFG Wisconsin Engines 20 05-29-2007 07:52:31 AM
