Welding Shop
H&M Welder Information
this thread has 6 replies and has been viewed 437 times
Old 05-19-2019, 07:13:45 PM
e7howie e7howie is offline
Default H&M Welder Information
I just picked up a H & M model TR-180 welder and would like to go through it before plugging it in. Does any person have any information on what to look for before I try to operate it? What do I need to look for. Any literature. Thank you in advance. Craig
Old 05-20-2019, 08:10:15 AM
Default Re: H&M Welder Information
Sorry, the welder is a P&H Model TR-180.
Old 05-20-2019, 02:06:53 PM
circuitman circuitman is offline
i also have a P&H welder(just learned what it was).i belive it to be of 225 amp or more.the best thing i can say is check the primary with a multimeter.be sure primary is ok , then check for faults to the case from both of the primary leads.then check secondary the same way.hook up primary to 120 volts first, then to 240 next. with one end of the meter grounded.with power applied check for stray voltages.if all is ok , which proabaly correct.ground frame. then check the secondary for output. if it checks out hook welding leads to it. see what it will do.does it have a crank on top & three output terminals? can you post some pics?
Old 05-23-2019, 11:56:52 AM
Here are a couple pics I have right now. Not sure why, but it looks as if someone scratched off the word "SINGLE" on the last line above the P&H.
ID:	335415   Click image for larger version
Old 05-24-2019, 02:01:59 AM
cobbadog cobbadog is offline
I think that the word 'single' was not removed intentionally, just a coincidence. Your plug (3 core wire) also denotes single phase.
Hope you can revive it.
Old 05-24-2019, 11:00:12 PM
mine looks like a coca cola machine.mine works great.this one should be able to get her going, keep us posted!
Old 05-24-2019, 11:24:41 PM
dalmatiangirl61 dalmatiangirl61 is online now
Are you sure it did not say "Three", and someone re-wired it for single (most likely with a lower rating)?
"Caterpillar D315 Twin Arc Welder " Anyone know specs for this vintage welder? mschreiber Welding Shop 1 08-15-2015 11:07:59 PM
Make an AC welder into DC welder? sdowney717 Welding Shop 8 11-13-2012 03:33:12 PM
Information Wanted on Welder MoRo Welding Shop 4 08-15-2012 07:36:35 AM
Depression era welder, still works good. Sell as a welder or antique? therrera Welding Shop 0 08-30-2011 10:09:54 PM
Need information on Sureweld Welder/generator Joecool48 Welding Shop 0 07-10-2010 05:56:23 PM
