Welding Shop
P&H TR180 Stick Welder
this thread has 3 replies and has been viewed 272 times
Old 05-31-2019, 02:33:57 PM
e7howie e7howie is offline
Default P&H TR180 Stick Welder
I have an old (50s - 60s)P&H 180 amp stick welder that works like a champ. I have two questions: 1 - I would like to replace the power cord with a 25 foot one. What gauge wire should I use? 2nd - The machine says it draws 37 amps. What size breaker should I connect it to (30 or 40 amp)? Thank you in advance.
Old 05-31-2019, 05:50:08 PM
Ken Karrow Ken Karrow is offline
Default Re: P&h tr180
If it were me #8 or #6 copper wire, 50 amp breaker. At 25 ft I'd lean to #6 unless you are planning very intermittent use as in small duty cycle.
Old 05-31-2019, 08:12:42 PM
Vanman Vanman is online now
Default Re: P&H TR180 Stick Welder
Another factor is the duty cycle of the machine. Many are as low as 20% on the highest setting, in which case a 40 amp breaker and #8 cord would be fine.
That said, a 50 amp socket is pretty well universal for welders. My mig only takes 22 amps, but has a 50 amp plug on it. The cord is probably #10 or 12.
Rather than replace the cord on the welder itself, you can make up a 50 amp extension cord using #6 cable. Then you can use it for other (future?) machines as well. And don't need to bother with it at all when the extra length is not needed.
Keith
Old 05-31-2019, 10:21:29 PM
ulgydog56's Avatar
I,m at 40 amp breaker, closer to spec. 8 for copper 6 for alum wire....
Carftsman Stick Welder johndeereboy1962 Welding Shop 7 10-18-2017 08:52:17 PM
Eutectic Magna Tran 301 stick tig welder ramsay Welding Shop 10 08-31-2017 09:24:27 PM
Hobart DC 200 A stick welder. Old lajs Welding Shop 1 03-08-2014 05:45:25 PM
How does an AC stick welder current control work? systemloc Welding Shop 1 09-18-2009 11:54:43 PM
Help: 6 cylinder 3KW generator/stick welder rcmule76 Welding Shop 0 01-14-2007 09:48:29 PM
