Magneto oil Suggestions
this thread has 3 replies and has been viewed 413 times
Old 06-03-2019, 10:05:31 PM
Camerons's Avatar
Camerons Camerons is offline
Default Magneto oil Suggestions
What are you guys using to oil your magnetos? I had an older gentleman tell me to use some Automatic Transmission fluid a few years ago so that is what I have been using. Is there anything better that I should be using?
Old 06-04-2019, 02:34:31 AM
cobbadog cobbadog is offline
Default Re: Magneto oil Suggestions
The only thing that I have used and that is only a drop is engine oil. I've had no problems in 8 years using it and because of the small amount no mess inside.
Old 06-04-2019, 07:08:39 AM
neverfear neverfear is offline
I use 3 in 1 oil and use it sparingly. I was told engine oil gets gummy over time and can cause problems.
Old 06-04-2019, 07:23:34 AM
For the last forty-five plus years, the same oil that goes in the drip oilers. If it's my oil can, it's usually 10/40 Pennzoil. If it's someone else's oil can, it's whatever they put in it.
MEP 002A looking for suggestions harryg Military MEP and Aircraft Gen-Sets 14 07-17-2012 05:15:45 PM
Air compressor suggestions? Bruce A Hit & Miss Gas Engine Discussion 11 12-22-2008 11:52:45 AM
2cyl magneto suggestions? David Parfitt Magnetos, Ignition Coils and Spark Plugs 6 12-06-2008 11:23:53 PM
I need your suggestions... LB Info? Sam Simons Hit & Miss Gas Engine Discussion 5 09-16-2007 10:17:27 PM
any suggestions? Tim Antique Engine Archives 4 01-27-2004 10:00:14 PM
