Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
Computer, Camera and ISP Problems Solutions for accessing and using the SmokStak® boards. Posting pictures, preventing viruses and solving internet service provider problems.
Need Spark Plug on a 5 HP Domestic
this thread has 3 replies and has been viewed 308 times
Old 07-24-2019, 11:03:07 PM
Dumpster Dumpster is offline
Default Need Spark Plug on a 5 HP Domestic
What can I use to replace this broken spark plug. The engine is a 5HP Domestic battery and buzz coil. The existing plug is a "Champion A-25". The Autostore just shook their head. Please see the pictures. Thanks
ID:	339934   Click image for larger version
Old 07-25-2019, 12:53:21 AM
LCJudge LCJudge is offline
Default Re: Need Spark Plug on a 5 HP Domestic
That's one of the long reach plugs. It doesn't have to be that long and a regular Model T Spark Plug will work. You can find them from the vendors on Harry's or simply do a google search or type in "Model T Spark Plug" on ebay and you can find them from $4 or so on up.
https://www.ebay.com/itm/Spark-Plug-...UAAOSwkCZcpLR8
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 07-25-2019, 07:25:29 AM
As Tommy also wrote, the plug for your engine does not need to be long-reach. A standard length "Model T Ford" plug is fine. The Autolite number, I believe, is 3095; your local parts store might have them on the shelf but would likely have to order them.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 07-25-2019, 04:17:40 PM
The A-25 is a modern version of the Champion X, used in the model T fords. Both still made. The A-25 was made in 2 versions, like the X was - one piece and take apart. The take aparts made for east cleaning, if the plug fouled, but were more expensive. The 34s were always take apart. Your plug looks like a Champion 34-gas engine special. You see them on EBay once in a while. nearly any plug with a 1/2 pipe base thread will work, as others have noted.
splitdorf spark plug anyone know what it would have been in very unusual plug Britstand Smokstak Down Under 6 09-04-2016 08:00:28 PM
Briggs WMB Spark at Wire but Can't See Spark at Plug KubotaDiesel Small Air Cooled Gasoline Engines 15 05-05-2014 11:15:05 AM
AC Spark Plug Div 4 Break Metal/Ceramic Plug? Bud Tierney Magnetos, Ignition Coils and Spark Plugs 3 01-08-2013 08:08:52 PM
Replacement Spark Plug for Maytag Uprights?? Modern Plug? enginesilo Maytag Engines and Collectibles 3 08-31-2008 01:21:57 AM
Domestic Spark Plug Charlie Bryant Hit & Miss Gas Engine Discussion 4 02-12-2007 09:27:43 AM
