Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
Lindsay Air Compressor Parts - Where to get?
this thread has 4 replies and has been viewed 9107 times
Old 02-26-2009, 04:09:01 PM
jrk jrk is offline
Default Lindsay Air Compressor Parts - Where to get?
I have an old Lindsay air compressor it s a model 55 with a wisconsin engine.The engine runs good but the compressor part doesn't make consistent pressure. I was thinking about rebuilding it if parts are available. I have had no luck finding anything. Any suggestions? Thanks
Old 02-27-2009, 09:22:17 PM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Default Re: Lindsay Air compressor parts. Where to get
Hi jrk, welcome to the sometimes lonesome world of Lindsay..
Is your unit a T55A with a VH4D Wisconsin engine ?
if so, it shows in the 1960 paper I have, it will put out 55-60 CFM Other than the listed parts vendors on the web who claim to have Lindsay parts I'm at a dead end for parts on the old ones. You might want to learn about and check your unloading circut.. it sounds like it's kicking out or half out..
good luck ! Randy Hart Ohio
He who dies with the most STUFF wins!
Old 03-05-2009, 04:44:56 PM
jrk jrk is offline
It has a vf4d I believe. From what I understand it was used in skid steers as well. I'll try to figure out something on the unloading circuit. It works ok for what I'm using it for but if It breaks down I think I'm out of luck. Then I'll have to repurpose the motor. Thanks
Old 08-14-2018, 12:13:39 PM
lantee lantee is offline
have a Lindsay e22l 6960 compressor. looking for parts Wisconsin engine
Old 08-14-2018, 04:12:39 PM
gdstew gdstew is offline
Default Re: Lindsay Air Compressor Parts - Where to get?
Welcome, you may want to post your needs in the Wisconsin section.
Briggs-Lindsay Air Compressor Garry Carpenter Hit & Miss Gas Engine Discussion 6 05-01-2013 09:23:25 AM
fh Lindsay compressor SBreeden Small Air Cooled Gasoline Engines 7 06-04-2012 09:51:50 PM
Lindsay Air Compressor Tim B YouTube Old Iron Videos 8 08-16-2011 08:25:35 PM
Lindsay Air Compressor, Briggs W :0 Randy Hart Small Air Cooled Gasoline Engines 9 01-25-2011 11:02:19 PM
P.K. Lindsay Portable Air Compressor RBWK Hit & Miss Gas Engine Discussion 2 01-06-2011 09:45:16 AM
