Oil Field Engines
Lorain Engine
this thread has 26 replies and has been viewed 7786 times
Old 10-06-2009, 05:17:47 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Default Lorain Engine
I went on vacation for nine days and when I came back home I found this engine in front of my shop. I guess a scrap guy left it for me. I'm sure he will come by in a few days to collect scrap money. I have never seen a Lorain and do not know anything about them.
The tag reads ser#542, Bore 7.5,
Stroke 8, 21 hp, made by the White Roth Machine Corp, Lorain Ohio.
This is a 2 cycle gas engine with a cross head. ensign carb and a mechanical single feed oiler. This engine is very complete and shouldn't take much to get running.
Does anyone have any history on the company? I'm guessing the years on this to be late 40's or early 50's?
ID:	64339   Click image for larger version
ID:	64340   Click image for larger version
ID:	64341   Click image for larger version
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 10-06-2009, 07:09:57 PM
Gerlacr Gerlacr is offline
Default Re: Lorain engine
Dwayne
Most of us have a hard time finding engines and you have people dropping them off at your door step. You must be doing something right.
RonG
Rockwall, Tx
Orange, Ca
Old 10-06-2009, 08:18:48 PM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
I wish Scrapaclaus would come visit me!!!
Old 10-06-2009, 09:22:15 PM
Reed Engine's Avatar
I have one like that too, a guy gave it to us just for hauling it off. My radiator is gone though.
Old 10-06-2009, 10:50:35 PM
Allan Wright Allan Wright is offline
Looks like a cross between an Ajax and a Witte.
Allan
Old 10-06-2009, 11:44:29 PM
DirtbikePilot DirtbikePilot is offline
I just picked one up in Colorado a few weeks ago. I went to an oil field equipment dealer for some FM ZC 503 flywheels for my 15 hp Z, saw the Lorain, and had to have it. It was missing the ignition, exhaust flange, clutch, and had some broken lubricator parts. I have found everything but the clutch now. I will probably never find a clutch, but that's ok. It will run without that. It has good compression and feels like all the bearings are good. I hope to have it running by next summer. It will only take that long because I'm getting a 25 hp Superior this week, and it comes first.
Name:	lorain engine.jpg
Old 10-06-2009, 11:46:31 PM
BTW, it is a 7.8x8 bore and stroke and is rated at 24 hp and 600 rpm. I doubt it will ever see more than 300 as long as I own it though.
Old 10-07-2009, 12:30:00 AM
Doug Waggonner's Avatar
I dont know any of the company history but they are a very well built engine. As far as I know they are the only 2 cycle oilfield engine with a replaceable cylinder liner. Too bad Ajax never did this
Old 10-07-2009, 09:12:34 AM
Thanks for all the replies guys. I was really behind yesterday since I was gone for 9 days, but I couldn't stand it and just had to turn a few bolts on the Lorain. Inside the crankcase is real clean and oily. Took the head off and didn't look to bad there either. I took the exhaust flange off and there is where the piston is stuck. Soaked it with penetrating oil overnight and will see if anything moves today if I get time.
Old 10-07-2009, 09:15:29 AM
dirtbikepilot, where does the line from the oiler go? That seems to be the only thing missing on mine.
Dwayne
Old 10-07-2009, 05:30:01 PM
It goes into the top of the cylinder, just like on the smaller Ajax engines.
The Following User Says Thank You to DirtbikePilot For This Post:
Old 10-08-2009, 08:39:28 PM
You missed one, the 5 x 6 1/2 has a wet sleeve.
Old 10-08-2009, 09:30:42 PM
Holy Crap! Sure enough! Well, I actually knew that......I just forgot.
I think you have the last NOS 5 X 6 1/2 left in captivity dont you?
Old 10-08-2009, 09:33:58 PM
I sure wish we could edit our own posts here!
What I meant to say was.... "you have the last NOS 5 X 6 1/2 sleeve left in captivity dont you?"
Old 10-08-2009, 10:30:54 PM
Craig Donges Craig Donges is offline
Years back I lived not but a couple blocks from the old Lorain plant. If memory serves, the names was still visible on the side of the buildig. Wishing now I would have a gotten a photo.
Craig Donges
Old 10-09-2009, 08:48:12 PM
sadly (now followed by extra letters to make the 10 limit)
Old 10-11-2009, 11:40:53 PM
Well I finally got a little time to work on the Lorain today. The piston has been soaking since Tuesday and still seems to be stuck as a few blows from the sledge and oak block didn't budge it. I was hopeing it was not stuck bad as most everything is still oily in the crankcase. Looks like a little more soaking time and some hydraulic force may be needed.
The scrap guy that dropped the engine off came by to see if I wanted the engine. He figured I did as I was working on it. I had to pay him 300.00 as long iron is bringing 5.50 per 100lbs. I told him to keep bringing all engines with flywheels and I would take them all.
Old 10-12-2009, 09:36:18 AM
antiquecarman antiquecarman is offline
dwayne,very nice engine.be patient with the penetrating oil.i soaked that fm i just got for two weeks in kroil.turned over like new.just needs time to soak all the way through.keep adding to keep it wet.hey are you going to granbury this week end?i am, suppose to be perfect weather.
just thought of something.how about i bring my dually over to your place for awhile and see if the scrap fairy will leave me something!
Old 10-12-2009, 12:25:43 PM
I am not going to Grandbury as my son is playing in a tournement in Shreveport, LA. There should be a man at Grandbury with a 4hp FM N. His name is Bill Keene, he may can give you some pointers on your 25hp.
I will be tied up all weekend with dad duties.
I have the Lorain soaking with Kroil as it is the best for stuck pistons.
Bring your Dually on over and it may well leave with some kind of loosely organized scrap iron in it.
Old 08-26-2011, 04:45:47 PM
Jerry Sweet Jerry Sweet is offline
A little more information on the Lorain engine.
Lorain steam whistle info needed Jim Thistle Steam Stationary Engines, Traction Engines 1 01-02-2015 07:00:56 PM
Lorain TL-25K Crane w/ CAT D-315 engine lpato Vintage Diesel and Oil Stationary Engines 5 07-04-2012 12:40:27 AM
Lorain engine? John Willis Oil Field Engines & Related Equipment 7 08-23-2011 10:50:58 PM
Lorain gas engine? Reed Engine Oil Field Engines & Related Equipment 4 07-26-2009 08:49:20 PM
