How we cap a chimney around here...
this thread has 0 replies and has been viewed 1516 times
Old 11-02-2009, 05:40:05 PM
Rene Elliott Rene Elliott is offline
Default How we cap a chimney around here...
Bits and pieces of Linn tractors found there way into most everything around this village (Morris), the frame rails ended up in bridge guardrails or street guard posts on corners or around fire hydrants, driveway culverts, concrete floors, etc. and the iron sheets off the floor in old dump boxes cover more than one septic tank in town(until liability made the village replace with floppy fiberglass), and this is how to cover up an unused chimney. Weight about 35 pounds. The track (or "lag") pin holes are pretty well worn in this one but the high ice creeper attachment is still good. I have seen these creeper grips used for barn door handles at an old logging camp I once visited. I had a great quanity of NOS radiator mounting springs so I used them to support the reinforcement wire when we poured a concrete floor. A guy up north took the strings of these tracks (about 26 lags per string, depending on model) off a Linn and used them for the footers for the wall of his garage. Anyone else re-use old tractor parts?
The Following 6 Users Say Thank You to Rene Elliott For This Post:
Asbestos liner for Hot Tube Chimney Jim Gorter Oil Field Engines & Related Equipment 5 08-17-2006 09:56:25 PM
Weber 5 HP Hot Tube chimney Wayne Grenning Hit & Miss Gas Engine Discussion 6 04-28-2006 11:46:51 PM
asbestos for hot tube chimney Coolhand Luke Hit & Miss Gas Engine Discussion 6 03-30-2005 08:32:30 AM
Hot-tube Chimney Greg Mosley Antique Engine Archives 4 09-02-2004 10:36:30 PM
Hot tube chimney liner Tom Winland Antique Engine Archives 0 08-29-2001 09:44:11 AM
