Right Hand - Left Hand Mixers
this thread has 6 replies and has been viewed 1743 times
Old 03-07-2010, 10:49:13 PM
Jim OBara's Avatar
Jim OBara Jim OBara is offline
Default Right Hand - Left Hand Mixers
When a mixer is described as a LH Fuel Mixer, or a RH..how can you tell which it is by looking at it.
Old 03-07-2010, 11:10:05 PM
Default Re: Right Hand - Left Hand Mixers
LH-RH denotes which side of the mixer the fuel line connects.
Jim
Old 03-08-2010, 03:25:47 PM
John Davis's Avatar
John Davis John Davis is offline
Jim,
On a mixer LH & RH stands for which side the Fuel lines is on in relation to what? intake engine side? intake air side? or mixer knob? Three guesses lets see if you get it correct.
Old 03-08-2010, 04:22:50 PM
While looking at the mixture knob on a LH Lunkenheimer mixer, the fuel line will be on the LEFT side of the mixer. If this is not clear, I can post a photo as I have one sitting on the desk right now ready to sell.
As to your quiz, John, are there other ways to describe them ?? If so, I have never heard of it. Not trying to be funny.
Jim
Old 03-08-2010, 04:31:22 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
From a 1908 Lunkenheimer catalog.
Larry Evans
The Following 3 Users Say Thank You to Larry Evans For This Post:
Old 03-08-2010, 04:38:32 PM
One can not argue that one, Larry. My 3/4" is marked as LH and is supplied to the left of the mixer needle.
If John has other info, I sure would like to hear of it.
Jim
Old 03-08-2010, 10:33:43 PM
John Davis's Avatar
You got it correct Jim, not that I'm a expert. I figured it out a few years back when I purchased a little marine engine that had a LH Lunk on it with throttle control. The intake on mixer that goes into the engine is not always in the same direction in relationship to the mixer valve. Different on some of the marine mixers.
The Following User Says Thank You to John Davis For This Post:
Left Hand/Right Hand Engine standard? Mark L. Jordan Steam Stationary Engines, Traction Engines 7 06-26-2015 07:07:54 PM
Reid left hand to right hand. OldironPhil Oil Field Engines & Related Equipment 12 01-10-2009 10:13:06 AM
Left Hand Tap M8 JKWidener Machine Shop and Tool Talk 4 12-14-2006 09:18:56 PM
Reid: Left vs: Right hand Rich Hudak Oil Field Engines & Related Equipment 1 11-23-2006 11:49:08 PM
Right or left hand rotation Gene Fisher Hit & Miss Gas Engine Discussion 0 01-25-2005 07:27:55 PM
