Oil Field Engines
Flywheel Engine Starter
this thread has 28 replies and has been viewed 15873 times
Old 07-26-2010, 12:08:48 PM
Bill Prine Bill Prine is offline
Default Flywheel Engine Starter
A friend of mine has an oil field engine starter that was built by Fairbanks Morse. It uses a 12 volt starter geared to a friction wheel that presses against the face of the flywheel. Does anyone know where one of these can be purchased?
Thanks,
Bill
Old 07-26-2010, 07:52:32 PM
Exclamation Re: Flywheel engine starter
If such a unit was factory made, I would like one too!
Old 07-26-2010, 09:02:04 PM
Heins Heins is offline
Default Re: Flywheel engine starter
I have a frame that you can mount a single cylinder engine on with a friction pulley to start oil field engines by the flywheel.
Old 07-26-2010, 10:01:48 PM
Reed Engine's Avatar
Oh they make them but they cost $1400.00. Makes that old hand crank look way better.
It's way cheaper to find a young, strong and not too smart fellow to help crank. An occasional hamburger goes a long way.
Old 07-26-2010, 11:14:31 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
Does it looks like this one:http://www.arrowengines.com/media/990starter.pdf
Keith
Keith Kinney
www.HerculesEngines.com
The Following User Says Thank You to Keith Kinney For This Post:
Old 07-27-2010, 07:33:46 AM
That's the one.
Old 05-05-2013, 05:52:06 PM
AZ Gary AZ Gary is offline
Where can you find one of the manufactured 12v starters. I have a friend who is looking for one. Could you send a picture of one if you have it?
Old 05-05-2013, 08:40:02 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
There is one available now called the Wilson Pinstar, see http://www.wilsonpinstar.com/ps.html They also show a price list of parts that would be good reference if one was to build their own unit.
Starter unit is $795, $995 with cables & control box.
They also make a gas engine powered unit.
The Following User Says Thank You to Jack Innes For This Post:
Old 05-05-2013, 08:49:27 PM
I've heard about pinstars for years but I've never seen one or knew anyone who owned one. I am a retailer so I'm going to talk to them about their product, might be something I can sell as I have a lot of customers that could use one. IF they are worth a flip.
I just sold an Arrow 990 the other day and they are currently $1600.00 retail now.
Old 05-06-2013, 09:05:05 AM
legendenergy legendenergy is offline
Talking Re: Flywheel engine starter
Most of the old ones I've seen were made by "Happy" out of Oklahoma. You start the "starter engine" then push down with your foot to make the friction wheel go agaainst the flywheel. A place in Elinwood Kansas called the Tinker Shop used to make one using a Ford starter and solonoid and used a wireline stripper rubber as the friction wheel. They worked well. I used then on FM 503 and 739 as well as C-96 and C-106's.
Old 05-06-2013, 11:55:12 AM
Walt Roys Walt Roys is offline
In Memory OF
I have done business with wilsonpinstar and they were reliable. The have friction wheels for sale. mine didn't work well, the starter engine turned too fast and didn't have enough torque. I'm now considering useing a vayiale speed chev that will allow contact at a much lower speed and then as starter engine speed increases, friction wheel will speed up. Has anyone tried this approach?
Walt
Old 05-06-2013, 02:40:49 PM
Here is a picture of one that used a single cylinder engine. The shaft, bearings, and friction wheel are missing. The second picture is what the owner used to start the 40 HP Fairbanks Morse engine.
ID:	164649   Click image for larger version
Old 05-18-2013, 07:08:35 AM
Glenn Ayers Glenn Ayers is offline
Here's a starter I built for our 20 hp Ball engine on permanent display.
I used a 3 hp electric motor that I had lying around. Had to use double reduction to get enough oomph. Now it isn't quite fast enough ... so when it fires I hafta get the tire off of the flywheel so it doesn't drag the engine down before the next "Fire". Even with my double reduction , it doesn't have quite enough balls & will kick the breaker sometimes. I need about a 5 or 6 hp motor .. gear it back up a little & it would be perfect.
Notice the rubber tire particles laying in the oil trough of the bedplate.
I never finished the engagement stuff ... I just insert a bar into a pipe welded to the thing & pull the bar up to engage the tire. The whole gizmo hinges off of angles that are screwed to the rr tie bed.
ID:	165485   Click image for larger version
ID:	165486   Click image for larger version
ID:	165487   Click image for larger version
The Following 2 Users Say Thank You to Glenn Ayers For This Post:
Old 06-19-2013, 11:02:25 AM
bwest bwest is offline
Just talked to the Wilson-Pinstar people about a starter for my 346 Fairbanks I am using in the oil field. Very nice people (daughter-in-law of the founder). I think I will be ordering one soon. I am getting too old to crank 346 cubs. lol Thanks for posting!!
Old 06-19-2013, 10:43:18 PM
dkamp dkamp is offline
eMail NOT Working
Y'know... Horror-Fright has these 5hp Honda clones for a hundred bucks... that, with a few pieces of steel from the scrap pile, a lawn-tractor tire and some chain would solve such problems on-the-cheap....
Old 07-28-2013, 07:30:59 PM
C Wells C Wells is offline
I have a Wilson Pinstar 12 volt to start my Witte diesel-6hp-would not be without it!
Old 02-01-2014, 11:54:54 AM
flywheelerjohn flywheelerjohn is offline
How about this idea for a starter??http://youtu.be/2PAFsqR1PAs
Sorry site doesn't work
Last edited by flywheelerjohn; 02-01-2014 at 11:56:47 AM. Reason: site doesn't work
Old 02-01-2014, 12:00:02 PM
I just sold my first Wilson Pinstar this week. The customer has yet to tell me what he thinks. The owner at Pinstar did give us the option of returning if he's not satisfied. His FM 503 will tell the tale.
Old 02-01-2014, 10:08:20 PM
Fifty7ChevyNut Fifty7ChevyNut is offline
i had a bunch of logs to get sawed, and there was an amish sawmill near by, i took a load of logs over, and was looking at his set up. he had a large diesel power unit, but now starter. on other side of engine, there was a gear reduction engine with dual belts, that was alligned to pulley on front of crankshaft. all of this was built on a slide. to start the diesel, they would start the briggs, and lean back on it, tightening the belts and cranking the engine. maybe you could do something similar with an older little engine to start the big engine. not quick, but would make the show more interesting. necessity breeds invention,
the nut
Old 02-01-2014, 10:39:29 PM
larry bee larry bee is offline
There was a gentleman in bay city Michigan that owned a machine shop called ryes machine shop. I happened to stop there one day on another note a seen that he had a lot of big oil field engines setting around. He was getting to old to work in the shop but was there every day. In talking to him he stated that all he did was rebuild engines for the oil fields when he first got going. He was telling us about guys breaking ther legs trying to start the bigger engines because they would stand on the flywheels to get them going. He showed us a battery operated starter that seemed to be made out of a starter that he had designed and built in his machine shop and sold lots and lots of them to the oilfields. They looked like they were just the ticket for starting those bigger engines. They were very portable and simple to use. Have no idea on price. Could get more info if needed. Let me know if interested. My email is cbelonga@att.net
Interesting comparison Onan J series starter & GM starter Tracy T Onan Generators 5 02-16-2016 10:33:04 PM
Onan Flywheel Electric Starter Info iceman Onan Generators 5 09-07-2015 10:11:02 AM
AKN Starter Sheave / Flywheel Removal Wekadog Wisconsin Engines 2 12-07-2013 10:19:56 PM
Onan 7000 needs expertise in NE Oregon, starter not moving flywheel brisath Onan Generators 7 08-04-2013 09:40:44 PM
How to remove Recoil Starter from Flywheel? Harold Stratton Small Air Cooled Gasoline Engines 11 10-18-2011 12:05:52 PM
