Oil Field Engines
Flywheel Engine Starter
this thread has 28 replies and has been viewed 15780 times
Old 02-09-2014, 07:31:05 PM
Default Re: Flywheel engine starter
[QUOTE=larry bee;1008411] Could get more info if needed. Let me know if interested.
Please do & let us know. Some pics and a component list would be great! Bill Klein
Old 02-09-2014, 09:29:18 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
I've posted this link before but maybe not on this page. I took these photos of an engines starter several years ago at the Portland show. I thought it was a real slick outfit.
http://herculesengines.com/starter/
Keith
Keith Kinney
www.HerculesEngines.com
The Following User Says Thank You to Keith Kinney For This Post:
  #23
Old 02-17-2014, 10:17:28 AM
doycowz doycowz is offline
I just purchased a Fairbanks Morse and it had a starter with it,, just a car starter with a push button to engage it,, it won't turn the flywheel without the valve being compressed to release the compression but it works
Best Regards
Doyle Cowart
Old 09-17-2017, 06:58:40 PM
AZ Gary AZ Gary is offline
Do you still have any information on those starter motors for oil field engines made in MI by Ryes Machine shop
Old 09-17-2017, 08:46:17 PM
Reed Engine's Avatar
A follow up on the Pin Star starters. I've since sold several and everyone who has bought them loves them.
  #26
Old 09-17-2017, 11:48:18 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
Here is one I drug home and rebuilt. We gave it a name, so we wouldn't have one.
ID:	291522   Click image for larger version
ID:	291523   Click image for larger version
ID:	291524   Click image for larger version
Old 09-18-2017, 11:10:24 AM
Deerlope Deerlope is offline
This is what I recently put together and it works very well
Name:	old iron starter 001.JPG
Old 09-18-2017, 11:13:24 AM
I sure do wish I was allowed to edit my post it would save doubling up so much . Gere are the rest of my invention if you want to call it that.
Name:	old iron starter 002.JPG
ID:	291551   Click image for larger version
Name:	old iron starter 003.JPG
ID:	291552   Click image for larger version
Name:	old iron starter 004.JPG
ID:	291553   Click image for larger version
Name:	old iron starter 005.JPG
Old 09-29-2017, 08:12:29 AM
Peter Holmander Peter Holmander is offline
Default Re: Flywheel Engine Starter
Planning on making one myself for my 15 HP Reid if I live long enough. I bought a couple of old mud sucker trash pumps years ago at an auction and scrapped the pumps and framework, but I saved the engines. They both had running 2 cylinder Wisconsin engines on them with a reduction gearbox to a chain drive sprocket that drove the pump. Not sure what the reduction is, but it should be slow enough. Reid engines have kind of thin flywheels so I'm not too keen on putting heavy pressure on such a small area of the flywheel rim like the rubber wheels on the Pinstar starters do. If you look at the later model oilfield engines like the Arrows, most have really beefy flywheels on them. Always though a belt mounted between two small pulleys kind of like a belt sander is set up with a pivot to make contact. Or use the Sisterville clutch pulley with a smaller drive pulley similar to PTO pulley on the farm tractors. That's the plan I have in my head right now.
Interesting comparison Onan J series starter & GM starter Tracy T Onan Generators 5 02-16-2016 10:33:04 PM
Onan Flywheel Electric Starter Info iceman Onan Generators 5 09-07-2015 10:11:02 AM
AKN Starter Sheave / Flywheel Removal Wekadog Wisconsin Engines 2 12-07-2013 10:19:56 PM
Onan 7000 needs expertise in NE Oregon, starter not moving flywheel brisath Onan Generators 7 08-04-2013 09:40:44 PM
How to remove Recoil Starter from Flywheel? Harold Stratton Small Air Cooled Gasoline Engines 11 10-18-2011 12:05:52 PM
