Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Help On Chimney Build
this thread has 5 replies and has been viewed 1572 times
Old 10-11-2011, 12:46:32 AM
Jim Alexander Jim Alexander is offline
Default Help On Chimney Build
I'm redressing an older steam boiler that was originally built to Stuart 504 standards and scales. I spent a bit on a sheet of tin that is stamped with the old brick pattern that a lot of the old Germany manufactures used. I have enough left for the chimney. Any ideas how to build the chimney?
Thank you for the listen and look forward to all your comments.
Old 10-11-2011, 08:07:51 AM
chrsbrbnk chrsbrbnk is offline
Default Re: Help On Chimney Build
are you thinking of a round one or square? and what dia? that would help decide the tooling needed.
Old 10-11-2011, 08:37:40 PM
Thank you for the help!
I originally thought round, 1-1/8" in diameter. If that turns out to be impossible, I guess I could consider square.
I'm desperate at this point. I'm guessing the thickness is only around 26-28 gauge if that.
I deeply appreciate your help.
Old 10-12-2011, 12:10:30 AM
1.125 is pretty small dia to find a sheetmetal roller for it might be easier to get a cheap metal bending brake from say like harbor freight
Old 10-12-2011, 12:33:04 AM
Metal bending brake, thank you, I'll check that out. I've attached a picture of the project in hopes that I'll get some further input on what options you all might use in final finish of material. I was thinking of bluing the tin brick pattern panels and leaving the 3/8 bar stock natural steel color. I want to keep a great deal of depth to it. I was going to wrap the boiler in wooden slats, about half made, still not sure! I guess another consideration would be to paint the brick. I still need to insert a cat walk at the top of each side panel, possibly consider a ladder and railing. Please any one out there give me your take.
Thank you all.
Old 10-12-2011, 02:42:03 PM
Case Place Case Place is offline
Take a trip to Lowes or Home Depot and check out the plumbing department. There are some nice chrome plated brass tubes that might be just right. They are called "tail pieces". They are the tubes that go from the sink strainer assembly to the "P" trap. There are a couple different lengths. Scuff up the chrome plating with steel wool and then paint to suit your fancy. Larry
Larry
Chimney build, help how? Jim Alexander Machine Shop and Tool Talk 0 09-28-2011 01:29:56 AM
Chimney / Hot Tube / Bessemer HVFD FireFighter Hit & Miss Gas Engine Discussion 9 09-15-2010 08:39:45 PM
How we cap a chimney around here... Rene Elliott Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-02-2009 05:40:05 PM
Hot-tube Chimney Greg Mosley Antique Engine Archives 4 09-02-2004 10:36:30 PM
Hot tube chimney liner Tom Winland Antique Engine Archives 0 08-29-2001 09:44:11 AM
