Onan CCK compression ratio's
this thread has 4 replies and has been viewed 531 times
Old 03-13-2017, 01:12:50 PM
nolectric nolectric is offline
Default Onan CCK compression ratio's
I am wondering about Cck's compression ratio's both high and low compression heads. I clicked on the search button and nothing happened. Thanks for any information you might have.
Old 03-13-2017, 01:40:21 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Re: CCK compression ratio's
CCK gasoline generators are 5.5 to 1 compression. CCK vapor only sets are 7 to 1 compression. The industrial 3600 rpm capable engines are 7 to 1. A 5.5 to 1 compression head has a step between the circumference of the piston and the gasket surface. The 7 to 1 head is flat in the piston area. I have the 7 to 1 heads on my 5.0CCK that can run gasoline or vapor.
The Control panel
and gauges of my
7.5JB
Old 03-13-2017, 02:28:15 PM
Kevin K Kevin K is offline
The standard 5.5:1 heads give a compression reading of 100 to 110PSI. The high compression 7:1 heads give a reading of 130 to 140PSI. I have high compression heads on both of my LK's, and soon to be on two of my CCK's. I run on gasoline only, but the high compression heads reduce fuel usage. Hopefully this summer I will get a chance run a test on fuel consumption differences.
The Following 3 Users Say Thank You to Kevin K For This Post:
Old 03-13-2017, 08:51:15 PM
Thanks guys that's​ what I was thinking. I have a couple LK's ,a couple Cck's and a JC I would like to raise the compression on.
Old 03-13-2017, 10:05:34 PM
Motorhead's Avatar
I put a high compression head on the LK I just bought and after lapping the valves and checking the compression HOT, I got 122 PSI.
The Control panel
and gauges of my
7.5JB
VG4D LP compression ratio hogman2002 Wisconsin Engines 3 10-28-2016 02:24:02 PM
Compression ratio difference between an Onan CCK and a CCKB Motorhead Onan Generators 6 11-27-2012 12:16:56 AM
Onan JB Compression Ratio Leon N. Onan Generators 9 03-24-2011 09:40:10 PM
Compression Ratio Ted_Cool Onan Generators 15 02-22-2011 12:10:31 PM
Onan JB Compression Ratio Leon N. Onan Generators 3 03-05-2010 12:26:19 PM
