Smokstak Down Under
Steamin' Demon Clayton Cleaner
this thread has 3 replies and has been viewed 855 times
Old 05-20-2018, 04:56:07 AM
Benno1600 Benno1600 is offline
Default Steamin' Demon Clayton Cleaner
Hi all,
I've recently purchased an old clayton cleaner model 900 steam cleaner which also had the steamin' demon name. I'm having some trouble getting the fuel chamber of the diaphragm pump working. Does anyone have any information or experience with these machines?
Any help will be greatly appreciated. Thanks, Ben
Old 07-21-2018, 12:44:06 AM
Ian888 Ian888 is offline
Default Re: Steamin' demon Clayton cleaner
Hi. I've have a
---------- Post added at 02:19:51 PM ---------- Previous post was at 02:01:41 PM ----------
Hi, I have the same model cleaner and have just been through the process of rebuilding it.
Have you got all the parts?
---------- Post added at 02:23:34 PM ---------- Previous post was at 02:19:51 PM ----------
Sorry I'm referring to the fuel/water pump and regulator
---------- Post added at 02:44:06 PM ---------- Previous post was at 02:23:34 PM ----------
When I stripped down the pump I found the gaskets were fine so I cleaned everything up and put it back together. The problem with mine was the one way valves on both the inlet and outlet of the fuel and water section of the pump, I guess sitting around with stale fuel and water did the damage.. I finally got it running late last night
Old 07-21-2018, 01:46:41 AM
cobbadog cobbadog is offline
Default Re: Steamin' Demon Clayton Cleaner
Leaving fuel in carbies is always looking for trouble. It is the main issue on whipper snippers and chain saws that use those high speed carbies. They do get blocked up with what ever the crap is that is in the fuel we get today.
Soak it in thinners and ensure all the passages are clear and if any valves are free to open and close. I had an issue with a carby and the only problem was that I used to leave the fuel in the whipper snipper until one day it would not start. It took a while of soaking in thinners then using a can of carby cleaner with an extension tube on it to blast through the port and then once everything was clear it ran again. So now I use them then empty the fuel tank and run the carby dry. I have always turned the fuel tap off on the old mowers and never though about it for this situation, now I do.
Old 07-28-2018, 07:19:14 PM
I have been through the pump completely now. Everything seems to be fine but it just won't pump fuel. I can't figure it out yet. It has been sitting outside for a long time i think. I'd love to see how yours runs!
Clayton Cleaner Steamin' Demon Benno1600 Machine Shop and Tool Talk 0 05-27-2018 03:38:22 AM
Little Demon V-8 engine DOC0455 Scale Model Engineering 12 04-28-2017 08:37:40 PM
Clayton "Steamin' Demon" steam cleaner instructions needed Robt. The Junque Drawer 1 02-12-2013 07:57:20 PM
Are we Steamin' Again?? Beth V Steam Stationary Engines, Traction Engines, Steam Boats 6 06-06-2008 07:17:25 PM
