Onan Generator Goes Click Click Click
this thread has 74 replies and has been viewed 3106 times
Old 09-08-2016, 10:37:21 AM
Bbernardwarrior1991 Bbernardwarrior1991 is offline
Default Onan Generator Goes Click Click Click
I have an oldER Onan Generator model -4BGEFA26101G Serial # H900342364. It is on a Winnebago Warrior below the cab, not easy to work on. Muffler was coming loose so I tightened it up 9/7 at around 10 AM, started her up to make sure she worked and ran like a charm. Drove down the road maybe 20 miles and needed to microwave my coffer and cranked REAL hard for a moment, then went click click click. I tightened the main positive cable going to the GenSet and it tried to start for a second and click click click. Every thing I have read said check the ground and I can't find it anywhere. So much dust from the dirt roads. Any help please. I am not mechanic but also not afraid to try things.
Brett
Old 09-08-2016, 11:10:10 AM
HBSaunders HBSaunders is offline
Default Re: Onan Generator Goes Click Click Click
starter solenoid bad?
Old 09-08-2016, 11:24:20 AM
Tony Clever Tony Clever is offline
I have an old Fleetwood that acted just like that. Would start fine when plugged in to 120 VAC for long periods of time If the electric went out and after several hours later you tried to start it might crank hard for a little than click. Turned out to be the Deep cycle batteries were going bad, As long as it was plugged in it would keep them up enough to start the Generator but would discharge very fast. Just a thought from personal experience. The guys Who are smarter than me might have other solutions, this was just something I experienced.
The Following 3 Users Say Thank You to Tony Clever For This Post:
Old 09-08-2016, 11:27:10 AM
Dale Russell Dale Russell is offline
Go to an Automotive Store and get a Battery Post Cleaner tool and Clean both Posts on the Battery and the Inside of the Cable connections on the cables, replace the cables and tighten both and see if that fixes the problem. This is a good place to start. Hope this helps. Also as Tony says, the Batteries may be BAD.
Old 09-08-2016, 12:34:15 PM
Terminals on the deep cycle batteries are all green, but batteries themseleves are only less than 2 years old. I'll try cleaning the terminals and change wiring on them first. Any way to tell if batteries are any good? Will post back with details.
---------- Post added at 10:34:15 AM ---------- Previous post was at 10:19:38 AM ----------
Just went to the RV to try and start when both engine battry and deep cell batteris are used to start the generator and it bogged down my motor, still a click click noise. Thought maybe that indo may help in the diagnosis.
The Following User Says Thank You to Bbernardwarrior1991 For This Post:
Old 09-08-2016, 12:42:21 PM
Motorhead's Avatar
Have you checked to see if the generator is locked up or seized? Try pulling the spark plugs and see if it turns over. Make sure the plug wires are grounded and away from the spark plug hole in case the engine is fuel locked.
My 1939 WILLYS Pickup.
Bought in 1971
Old 09-08-2016, 12:43:41 PM
Definitely clean the terminals good, be sure to remove them so you get a good mating surface between battery and Connector. Also not sure if they are flooded lead acid, if so check the level of water in them. If that doesn't fix it, You might test the Specific Gravity of them, unless they are AGM or sealed lead acid but make sure you charge them first before testing. Another thing is make sure the cables connected back at the Generator are making a good clean connection. Good luck... Always best to approach the simple stuff first before jumping to the complicated parts.
Old 09-08-2016, 12:57:51 PM
len k len k is online now
Get an ice pick test light and clip lead on gen's +12 bat terminal and jab other end into frame of gen. Have someone crank the gen if light is real dim ( < ~ 9 V ) then you got a bad connection from bat to gen or bad bats.
With a little probing around you can track problem down to a specific bad connection. Did this all the time on cars.
Other variation of this test is put light across a suspect connection and crank engine if it lights a bit you found the problem.
Don't have a test light? Put spit ACROSS suspect connection and have someone crank engine, if bad connection then steam will rise, but ONLY while cranking.
The Following 2 Users Say Thank You to len k For This Post:
Old 09-08-2016, 02:08:33 PM
If it just goes click click hoe would I know of generater is locked up?
Old 09-08-2016, 02:54:59 PM
You said you can;t find the ground. That may be your issue. RV makers tend to go cheap as they can, there is (Was?) a ground wire from the 'floating' engine to the mounting base, but then they cheat and hope the mounting bolts ground it. Add a good heavy ground from the generator engine to the vehicle frame.
new toy ...click on video Eric McKenna Antique Gas Engine Discussion 1 10-29-2013 06:50:50 PM
magneto turns, no click? rockytopp Magnetos, Ignition Coils and Spark Plugs 9 07-17-2013 05:40:45 AM
OPINIONMART - NOT OURS - Do NOT Click Harry Computer, Camera and ISP Problems 0 03-16-2012 10:43:15 AM
Click to personal page Ralph Leonard Antique Engine Archives 1 12-22-2002 08:19:52 PM
