Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Maytag Model 18 Drain Hose Source?
this thread has 3 replies and has been viewed 1491 times
Old 07-01-2016, 01:19:52 AM
Damfino Damfino is offline
Default Maytag Model 18 Drain Hose Source?
The hose on my Maytag Model 18 rotted and cracked, and I cannot find a source for replacement hose material.
The outside diameter of the hose is in the range of 1-3/8 to 1-1/2 inches and fits inside a cast iron elbow of that size (under the tub), so the outside diameter of the hose is the deciding factor here, not the inside diameter.
The hose I get will have to be cemented into that elbow, so it's got to be a close fit to function properly.
I've been looking on the internet for hoses, but some are close in size, but not close enough.
Any hose help would be welcomed.
Many thanks,
Ken
Old 07-03-2016, 05:59:47 PM
Default Re: Maytag Model 18 Drain Hose Source?
Correction: The hose needs to be 1-1/4 inches OD to fit inside the flange.
The old hose (1-1/2 inches OD) must have been modified on the ends to fit inside that flange
Thanks,
Ken
Old 08-26-2016, 06:29:59 PM
Zen Zen is offline
I needed a new drain hose for a model 32 I recently purchased. I couldn't find anything close to the original hose locally, so I improvised. I got some 3/4 inch ID black hose from ACE. It fit on the drain outlet under the tub, but, being a thinner wall hose, it was too small for the flange that hangs on the tank. I cut about 2" of the best section of the original hose and bored it out to a tight fit over the replacement hose. Then I slathered the inside I just bored out with some black silicone and forced it over the end of the replacement hose. 99% of the people that look at it will never know the difference . . . and it works . . . and it was cheap.
Old 08-27-2016, 06:07:52 PM
Zen Zen is offline
On second thought, it might have been 7/8" or 1" ID. It's been a few weeks . . . I don't remember for sure. I'm also not sure exactly what kind of hose it was, but it looked and felt like automotive heater hose.
On mine, the drain under the tub has a flange the hose goes over and is held on with a hose clamp. I matched up the ID because of this. The old hose went inside the end piece that hangs on the side of the tub That's the end I used the piece of old hose on.
Maytag 80 drain hose spout needed macie1mike Antique Washing Machines 2 12-15-2014 06:42:14 PM
Maytag drain hose replacement cs222 Antique Washing Machines 1 05-30-2012 06:49:18 PM
Model 92 washer drain hose replacement John in Maryland Maytag Engine Collectibles 4 09-05-2011 05:25:25 PM
Model 92 Drain PLug/drain hole - thread size? redr2 Maytag Engine Collectibles 8 03-17-2010 11:13:56 AM
Source for wire hose clamps DavidRaines Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 11-24-2009 04:13:29 PM
