Briggs/Sears washer motor - What is it?
this thread has 12 replies and has been viewed 2566 times
Old 04-14-2009, 06:40:01 PM
Zira Zira is offline
Photo Briggs/Sears washer motor - What is it?
Picked this up last week. I am sure it is really a Briggs but I don't know much about them. What model is it, what should it have for a gas tank, was there a kick start on it originally? I am surprised by the stamped metal base & the big crank case breather.
ID:	52299   Click image for larger version
Old 04-14-2009, 06:56:42 PM
Bob Kurtz Bob Kurtz is offline
Default Re: Briggs/Sears washer motor - What is it?
I would say most likely an early Briggs WMB, and was probably on a washing machine. My 2 cents.
Bob
Old 04-14-2009, 07:39:02 PM
K D Redd K D Redd is offline
I concur, a WMB. Post the type number as I can I.D. for sure from the parts books I have. I have one just like it with the same exhaust manifold and LITTLE VACU-JET carb with no provision for an air cleaner.
Kent
Old 04-14-2009, 07:50:12 PM
hitnmiss hitnmiss is offline
Quick way of identifiying. If the spark plug is verticle, in the top centre of the head, its a WMB.
if the spark plug is horizontal, in the edge of the head, just over the carburator, its a WM
Old 04-15-2009, 06:18:51 AM
Except I've had a WMB with the horizontal spark plug.
Old 04-15-2009, 08:45:10 AM
The head has been changed or the data tag is not the original to the engine.
Kent
Old 04-15-2009, 09:18:05 AM
Kent
Does the engine have 4 cooling fins on yhe exhaust port or 2 cooling fins ? can't tell from picture exhaust manifold is in the way. if its 4 its a WMB if its 2 its a WM.
Old 04-15-2009, 07:01:58 PM
My engine, the one in the original pics, is a model 500.60924, series 97. Does that fit with a WMB? Is the stamped steel base normal?
Old 04-15-2009, 08:47:52 PM
Sky
I do beleive the WMB could be eaither way. Horizontal or virtical plug. I have a WMB with a virtical plug and the head IS original. I've said this many times over. It's hard to say definitly what briggs did or didnt do. There were so many diferent variations to please so many diferent clients it's hard to tell sometimes. Inless you have a big book about 12 inches thick that has the variations. Thats the usual stamped base.
Old 04-16-2009, 12:15:35 AM
Mike in NC's Avatar
Here is a link to a list of 5 digit Type Numbers and for 6 digit Type Numbers
SmokStak Member #28
Old 04-16-2009, 09:06:16 AM
Bob,
The picture were posted by Zira, Not by me.
Kent
Old 04-16-2009, 07:05:43 PM
Mike in NC's Avatar
Type 60924 would be for a model WM.
SmokStak Member #28
Old 04-16-2009, 09:26:29 PM
Kent
sorry about that Sometimes I get a little ahead of myself.
Briggs /Sears Roebuck ID DaveHC Small Air Cooled Gasoline Engines 2 06-12-2009 02:32:07 PM
Need help finding parts for Sears motor Dwight S Small Air Cooled Gasoline Engines 4 03-09-2008 08:02:05 PM
Sears radial arm saw motor 6hpMarty Generators & Electric Motors General Discussion 2 01-08-2005 04:28:16 PM
Sears Tag on a Briggs? Dan Bogart Antique Engine Archives 3 06-14-2003 03:34:38 AM
sears/briggs charlie frayer Antique Engine Archives 1 06-10-2001 09:29:34 AM
