Smokstak Down Under
Pump Designer on Drugs
this thread has 32 replies and has been viewed 2078 times
Old 10-07-2018, 01:52:16 AM
Darryl Darryl is offline
Default Pump Designer on Drugs
Opened up an inch and a half pump my Dad picked up at a clearing sale 50 years ago and found the stupidest impeller ive ever seen.
No wonder they didn't put there name on it anywhere.
Cast iron housing, brass nuts all over and a brass impeller.
Anyone know anything about it ?
Old 10-07-2018, 02:20:19 AM
rodneyt rodneyt is offline
Default Re: Pump designer on drugs
53 words down, 947 to go...
The Following User Says Thank You to rodneyt For This Post:
Old 10-07-2018, 02:46:17 AM
What , no photos.?
Old 10-07-2018, 02:47:58 AM
That took me at least 10 mins to work that out.( big night last night)
Old 10-07-2018, 02:50:12 AM
Famous Fitter Famous Fitter is offline
Highly efficient design..............NOT.
Old 10-07-2018, 02:59:39 AM
E27N's Avatar
E27N E27N is offline
Itís actually a manifold.... It just identifies as an impeller......
I love the smell of 515 in the morning...
The Following 2 Users Say Thank You to E27N For This Post:
Old 10-07-2018, 03:08:03 AM
Another angle.
Old 10-07-2018, 03:17:57 AM
Craig Gillingham Craig Gillingham is offline
Seeing those round impellors in profile explains a lot. Mostly, how would they ever be effective?
Old 10-07-2018, 03:52:13 AM
Scotty 2 Scotty 2 is offline
Crikey. Certainly unusual. There's definitely some outside the box thinking happening there. Very innovative.
Can you take a picture of the other side Darryl? Something about it seems familiar to me.
Oh you gotta fix it up and get it pumping. Everyone will be curious just how well it will pump.
Cheers Scott
Old 10-07-2018, 04:51:44 AM
fascinating
what forces are happening to the fluids when operating ?
maybe the thought was to obtain the maximum pressure by having the fluid exit the impellor as near to the maximum radius from centre as possible,
this might theoretically make it more efficient?
or if not efficient,
maybe maximum pressure for minimum revs, note the large pulley?
another possibility is an attempt to make a 'no prime' pump.
i can imagine this design might actually pump air, and so create small vacuum?
as already said, now you gotta fix it and find out what it does!
on first sight it actually looks more like a rotary motor...
thanks Rod.
Hardie Model 99 Senior Duplex Pump (Sprayer Pump) parts? MotoXkid Farm + Industrial Antiques and Collectibles 25 02-08-2017 12:41:01 PM
Kudo's to the Armature Housing designer Nick Lingg Antique Gas Engine Discussion 0 04-24-2014 03:30:47 PM
Deane steam pump co. water pump info needed Nick McCue Antique Gas Engine Discussion 2 08-07-2011 06:59:51 PM
Ebay find,Monitor Pump Jack engine complete with pump and arms Benny Mckheean eBay© Auction Discussion 1 09-02-2005 06:27:14 PM
