Wisconsin Engines
Unknown Wisconsin needs IDed
this thread has 6 replies and has been viewed 616 times
Old 05-29-2018, 01:15:44 AM
Ogrebeast64 Ogrebeast64 is offline
Default Unknown Wisconsin needs IDed
It came with a starter/generator that turned out to be bad. No ID tag at all, and it was a battery ignition system.
ID:	311401   Click image for larger version
ID:	311402   Click image for larger version
Old 05-29-2018, 06:55:03 PM
Zira Zira is offline
Default Re: Unknown Wisconsin needs IDed
Looks like AEN or AENL. If you are not going to pull the head, get the numbers off the mag or carb.
Old 05-29-2018, 08:41:53 PM
K-Tron K-Tron is offline
Last I checked, an AENL has 6 head bolts not 8. That is a Wisconsin BKND with a pretty unusual Prestolite distributor setup.
Old 05-29-2018, 08:56:40 PM
Phil P Phil P is offline
Hi
Chris nailed it I would say the same because of the shape of the head.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 05-29-2018, 11:40:09 PM
Many thanks for the ID on this one. I have only seen one other like this one with the battery ignition, and it was on an OLD Snapper rider.
The carby is definitely a Zenith, and the only things I can find stamped on it is Zenith Made in USA. I've listed it on Craigslist and Facebook Marketplace. No bites on it though.
Old 05-30-2018, 01:13:36 AM
What was the trouble with the starter generator?
Old 05-31-2018, 12:54:36 AM
No voltage output. Cleaned all contacts in the regulator, and also cleaned the commutator/brushes. The regulator worked fine on a different generator. The only thing I didn't have was a growler to check the armature.
WISCONSIN Tractor Plowing at the 2017 Badger Steam and Gas Show, Baraboo, Wisconsin Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-30-2018 12:06:21 AM
two unknown wisconsin's Charliechaindrive Wisconsin Engines 6 01-31-2013 08:40:48 AM
Wisconsin, unknown twin, weak spark on one cylinder Cheddarpecker Magnetos, Ignition Coils and Spark Plugs 9 01-05-2012 07:36:04 PM
Unknown Compressor that has a Wisconsin Engine VH4D jesters13 Farm + Industrial Antiques and Collectibles 7 02-01-2011 11:56:09 PM
Unknown Wisconsin Air compressor unit. adamsrj Wisconsin Engines 3 12-18-2010 07:41:55 AM
