The 6hp. Field-Brundage in Crosby, N.D.
this thread has 4 replies and has been viewed 493 times
Old 10-15-2018, 09:37:26 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is online now
Default The 6hp. Field-Brundage in Crosby, N.D.
Here is a video on you tube of engine #4773
https://www.youtube.com/watch?v=sBShI4stnh8
This is a Field-Brundage that is a close match to my Rayner Field engine.
Since we will be working on my engine this Winter, I would like to see some close up pictures of this FIELD in Crosby, as this engines seems to be very complete and original.
I need a contact(s) to anyone having access to this engine and willing to take close-up pictures (in particular of the governor assembly).
Thank you!
Denis Rouleau
Old 10-15-2018, 11:18:29 PM
JWithers JWithers is offline
Default Re: The 6hp. Field-Brundage in Crosby, N.D.
That is a video I shot a couple years ago. I sure do like that engine. The owner of that engine is on here from time to time. I'll see if I can get word to him if he doesn't see this first.
Jeremy Withers
The Following User Says Thank You to JWithers For This Post:
Old 10-15-2018, 11:45:28 PM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
Think there is a 4hp tank cooled just south of Ottawa that might be closer.
The Following User Says Thank You to Brian Triebner For This Post:
Old 10-16-2018, 12:37:22 AM
Kevin Aarestad Kevin Aarestad is offline
Hi Denis, I am the owner of the Field in the video and would be more than happy to take some pictures. Let me know what you need.
Kevin
The Following 3 Users Say Thank You to Kevin Aarestad For This Post:
Old 10-16-2018, 06:40:42 AM
Kevin
Kevin, glad I found you. Here is the Raynor Field that my friend Brian P. will help me correct all the little things needing attention to make it run better:
http://buzzcoil.brinkster.net/Field%...e/page103.html
I would like pictures of all sides of the engine for the Field-Brundage registry.
Also, since the first think we want to work on is the governor, I would like to see close up pictures of the governor's area and of the magneto area. Your engine, like mine has the Webster magneto which is not found on many engines. This is why I wanted pictures of your engine since it has the Webster magneto.
Do you think the gasoline tank is original on your engine? I have a good tank on mine but it is a recent fabrication and is too big so if yours is original I would like its dimensions to make one like the one on yours.
You can email me directly at: buzzcoil2@videotron.ca
Thank you very much!
Denis Rouleau
Field-Brundage (Rayner Field) 5-1/2hp. Denis Rouleau Antique Gas Engine Discussion 3 09-05-2018 01:53:04 PM
Field Brundage "Field Jr" /Ideal Type C /Novo 3 Hp Vertical Len Spoelman Antique Gas Engine Discussion 8 08-21-2018 02:59:27 PM
20 H.P. Field and Brundage fairbanks67 Antique Gas Engine Discussion 5 06-09-2016 11:52:03 AM
Field and Brundage jpalex Antique Gas Engine Discussion 4 12-10-2015 04:40:00 PM
Field - Brundage 7 h.p. dusty Antique Engine Archives 1 06-12-2004 08:32:06 PM
