Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Fairbanks Morse 208
this thread has 10 replies and has been viewed 1411 times
Old 12-31-2017, 12:44:33 PM
driller67 driller67 is offline
Default Fairbanks Morse 208
Hi! I have a Fairbanks Morse 208. According to the serial number 817958, it looks to me like it was made in 1940. I was wondering if anyone could confirm this and also when they started making the 208's as I have seen several different dates. Thanks, Walter
Old 12-31-2017, 01:28:09 PM
Russell Walker Russell Walker is offline
Default Re: Fairbanks Morse 208
It is a 1940 don't know start date.
The Following User Says Thank You to Russell Walker For This Post:
Old 12-31-2017, 01:33:26 PM
ok Thank you Russell
Old 12-31-2017, 07:48:10 PM
Reed Engine's Avatar
It amazes me how well these have lasted. Guess I need to ask, how do you date them by the serial? I see a lot that have dates cast on them but not that old. They seem to be in the. 50s or later.
Old 12-31-2017, 10:56:20 PM
Reed, I have a serial no list that I got off an internet site not sure what one any more but seams to be close to what other people have. I new the engine had some age on it because it doesn't have the inspection plate on the back of the block and it has a dip stick to check the oil. The lease that it came off of was drilled in the early 40s. My father -in-law got the lease in 1982. The engine broke a valve and was replaced looks like it might have been on that lease all its life. He let it set, then in 2016 I said I would like to fix one up and he gave it to me. It has been quite a job as it was pretty much wore out, but looks like I will have it ready to run at his 75th birthday.
The Following User Says Thank You to driller67 For This Post:
Old 01-03-2018, 08:48:19 AM
I have a 118 dip stick engine. One of these days Iím going to get it running. I guess I need to get the serial and see what it dates to.
Old 01-06-2018, 12:46:11 PM
Allan Wright Allan Wright is offline
1940 could very well be the first year they were made. I have seen a picture of a 1939 prototype. I have seen an article that the 118 was made specifically for shallow oil wells in California. The 208 could have been started at the same time.
The Following User Says Thank You to Allan Wright For This Post:
Old 01-06-2018, 03:46:30 PM
Mine cane with a lot of several from Sohio Oil Co. They had brass tags that said that. Iíll post a pic when I get back to the shop.
Old 01-07-2018, 01:27:39 AM
Mr. Reed I have a 118 and a 208 with a Sohio tag as well. Both are dipstick engines too. Mine did not have clutches, but had pulleys on the shaft. Makes me wonder if they were running pumps.
Old 01-09-2018, 05:16:39 PM
The tag on the 118.
Fairbanks Morse ZC 52 driller67 Oil Field Engines 3 04-18-2017 06:18:52 AM
Fairbanks Morse 2 HP Z D 34 40 Antique Gas Engine Discussion 32 02-26-2012 07:44:54 PM
Fairbanks Morse T 2hp Alex F Antique Gas Engine Discussion 2 09-30-2010 08:38:53 PM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Antique Gas Engine Discussion 4 09-12-2008 11:03:58 AM
Fairbanks Morse Za David Heggie Antique Engine Archives 4 12-23-2002 07:36:33 PM
