Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Mountville Sheller
this thread has 9 replies and has been viewed 907 times
Old 09-15-2017, 02:24:05 PM
wborum wborum is offline
Default Mountville Sheller
Is this a Mountville sheller? If not what kind is it and thanks for the help. Click image for larger version
The Following User Says Thank You to wborum For This Post:
Old 09-16-2017, 06:06:33 PM
Chuck H Chuck H is offline
Default Re: Mountville Sheller
A. Buch & Sons, Elizabethtown, PA
Old 09-16-2017, 11:11:25 PM
Should the metal plate have the name stamped in it or smooth like in the picture? Does this look original? Thank
Old 09-17-2017, 06:16:47 AM
Kevin G Kevin G is offline
Did A. Buch & Sons build these for some one else as well? The one I have is identical with the wooden fingers and the same discharge trough but has the remains of green paint on the main body if I recall correctly.
Old 09-17-2017, 08:13:18 AM
All the Buch's I've seen have no name cast on the metal plate. Some Mountville's have the name cast on the plate and some the top cover is all wood. Mountville's use a different system (pitman arm) to operate the shaker.
There's a number of companies that made similar shellers. Buch and Mountville are the most common. There's also Keystone, Farquhar, Hench & Dromgold, Dellinger and others. One thing that's different between the companies is the shape of the finials.
My opinion is the whole sheller has all been repainted. Hand crank doesn't look original either.
---------- Post added at 08:13:18 AM ---------- Previous post was at 08:06:59 AM ----------
Massey Harris made this style of sheller also. Or had it made for them? Only have seen one MH and it was green. Could explain the green on yours?
Old 09-17-2017, 08:19:26 AM
Thanks Chuck. I sure appreciate your help.
Old 09-22-2017, 06:08:37 AM
Chuck-just remembered to look at sheller last night. Main body is faded green with red on the upright posts and narrow green edge on each corner of those posts. Pin striping is in black and very fine. Name on one side says _ERR___ Co.( could be "H" or "M" at the start) and then below it says Toledo Ohio. On one end it says No. 20. The grate to allow the kernels to drop down in the discharge trough has rectangular holes with the ends rounded slightly. Any thoughts on who made have made it? Tia.
Old 09-22-2017, 07:30:07 PM
It would say The Merrell Co., Toledo, Ohio. They were jobbers not manufacturers. Had a 2-hole with the Merrell name on it. It was green and made by The Keystone Farm Machine Works, York, Pa.
The Following User Says Thank You to Chuck H For This Post:
Old 09-22-2017, 08:54:01 PM
Thanks Chuck-I really appreciate knowing more about this sheller. Is the manufacturer the same company that was later part of International Harvester?
Old 09-23-2017, 07:48:44 AM
Different Keystone. IHC acquired Keystone Mfg Co., Rock Falls, ill.
Malleable iron chain used on IHC 2 hole hand sheller and 2 and 4 hole power sheller. Tim Colwell Farm + Industrial Antiques and Collectibles 1 03-05-2017 07:07:38 PM
Mountville Corn and Bone grinder Jebaroni Farm + Industrial Antiques and Collectibles 16 07-24-2013 03:18:11 PM
Sheller ID Philip Winter Farm + Industrial Antiques and Collectibles 8 08-28-2012 05:27:59 PM
Champion, Mountville PA Corn Sheller JulieD Farm + Industrial Antiques and Collectibles 12 07-26-2011 09:46:32 PM
IHC Sheller Mike Schweikert Antique Gas Engine Discussion 2 02-17-2006 09:25:44 AM
