Oil Field Engines
12hp pattin cylinder honing
this thread has 2 replies and has been viewed 1639 times
Old 06-10-2013, 03:06:25 PM
carlglenn carlglenn is offline
Default 12hp pattin cylinder honing
A local machine shop is letting me borrow an 8 in. Hone for that reason I'm putting the valve work on hold.Unfortunatly I can only use it this Friday .So I will be missing coolspring !
Does anyone have a rec for head and valve chest gaskets?
Thanks Carl
---------- Post added at 03:06 PM ---------- Previous post was at 02:58 PM ----------
Thanks Carl
Pics to follow
Old 06-10-2013, 06:48:04 PM
Reed Engine's Avatar
Default Re: 12hp pattin cylinder honing
That machine shop guy must really like you, do you know what a 8" Sunnen hone costs? There's very few people I'll let use mine. Very few.
Good luck with all this. I'm still waiting on a YouTube of it running.
Old 06-11-2013, 09:39:49 AM
I too look forward to my dad turning the flywheel and hearing her bark for the first time since 1963
The Following User Says Thank You to carlglenn For This Post:
12hp pattin valve work carlglenn Antique Gas Engine Discussion 2 05-29-2013 01:55:13 PM
12hp Pattin Bros Retrieval Zach Williams Oil Field Engines & Related Equipment 17 08-30-2012 07:03:33 PM
Cylinder honing questions carlton Small Air Cooled Gasoline Engines 18 06-10-2008 04:58:52 PM
Hot tube for 12hp Pattin 4 cycle Tom Weatherford Antique Engine Archives 1 10-07-2002 10:48:28 AM
Cylinder honing Chris Kirk Small Air Cooled Gasoline Engines 2 07-02-2002 06:51:43 AM
