15hp Reid
this thread has 2 replies and has been viewed 1991 times
Old 07-09-2004, 02:14:17 PM
AFretired
Default 15hp Reid
I've been working on my engine the last few weeks. I have finally got everything apart without breaking anything. As I stated in an earlier post, the pistons were stuck as bad as they could be. My problem now is the extreme pitting in the cylinders. I'm sure others have been down this same road. Last night I put it back together and put some pipe fittings in the hot tube hole and hooked my air compressor to it. When I pumped in the air I had a lot of blow by. Any ideas? The only thing I can think of is having the cylinders sleeved, and I don't have a clue where to get something like that done, or if it would be financially feasible. David
Old 07-09-2004, 10:37:06 PM
Patrick McNallen
Default Re: 15hp Reid
I have a 15 HP Reid that has rust pitting at the crank end of the bore. It looks pretty bad, and it extends a good way into the bore toward the head end of the bore. It looks like the engine sat for years with leaves and dirt or rat's nests in the cylinder. The engine runs fine though, and has good compression. The more I run it, the better the rings seem to hold. If your rings look OK, I would assemble the engine and try it out for a while. It may have to run for several hours for the rings to re-seat. There is a lot of good information on fitting piston rings in the archives of this website and on some of this site's sponsor's web pages.
Old 07-11-2004, 09:05:16 PM
AFretired
Patrick It's nice to hear that your's runs good. It gives me some hope. I've not given up at this time. The main piston will probably be alright after it runs a little and the rings reseat. The rings look good and square, so hopefully they will work. I guess I need to get ready to belt it up to something. I don't think my back will stand trying to get it started.
sleeve for 15hp reid? Jon Powell Antique Gas Engine Discussion 0 01-30-2008 08:23:41 PM
15hp Reid Info Jim Gorter Oil Field Engines & Related Equipment 4 01-11-2006 12:15:47 PM
Another 15hp Reid Project DONE Pix Tom Schoolcraft Antique Engine Archives 0 10-09-2004 12:04:48 AM
15hp Reid Pix chase Antique Engine Archives 0 01-04-2003 02:00:49 AM
Re: Weight of 15HP REID Bill Tremel Antique Engine Archives 1 04-05-2000 02:44:53 PM
