Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
Jost Lampfan rebuild follow-up.
this thread has 6 replies and has been viewed 1472 times
Old 12-15-2016, 06:06:05 PM
Rodelu Rodelu is offline
Default Jost Lampfan rebuild follow-up.
After much penetrating oil and increasingly heavier hammers I was able to take the engine apart. Cannot tell wether or not the piston and cylinder will work as they are, my intention is to make the missing parts and give it a try.
The rod that slides inside the cylinder needs to be replaced, a new one is easy to make.
I'm extremely grateful to Brent Rowell for his assistance.
ID:	270332   Click image for larger version
The Following User Says Thank You to Rodelu For This Post:
Old 12-15-2016, 09:11:43 PM
Default Re: Jost Lampfan rebuild follow-up.
For your next post you should reply to this thread so all of your information stays in one place and not spread out over many posts.
Old 12-16-2016, 05:54:41 PM
Thanks for the advise; I'll do that in the future.
Old 12-17-2016, 01:42:46 PM
Brent Rowell Brent Rowell is offline
As we have discussed, I think the piston rings were probably added by a later restorer and are likely to create unnecessary friction. Here's a photo of my piston with only a single oil ring. The fit (seal) in the cylinder is so precise that it is very hard to pull out (but no friction). Today I've sent you about 40 photos of the linkages and parts that are missing.
Old 12-18-2016, 03:04:56 PM
Hi Brent;
Got your beautiful photos and drawings, thanks so much!
I'll make parts according to your drawings out of some engineering plastic or laminate, just to see if they work and to make sure I have the right dimensions for the linkages.
I'm planing to try the cylinder and piston as they are, if they don't work I'll rework them for a better fit.
Those rings in the piston are still a mistery; I see a lot of oiling holes in your photos which in a warm climate and with the fan working 24/7 would require daily attention but they may or may not get it. Perhaps the rings helped by retaining some of that lubricating oil, apart from sealing the air in.
Best wishes.
Old 12-24-2016, 12:44:59 AM
Lester Bowman Lester Bowman is offline
Better pay attention to Brent. ANY friction kills those little hot air fans.
Old 01-20-2017, 06:58:39 AM
myersenginewks myersenginewks is offline
Very nice engine. Do you have a finished photo of the engine?
Thanks Brent Myers
Myers Engines .com
Jost Lampfan rebuild. Rodelu Hot Air Engines 14 12-10-2016 04:50:18 PM
Jost Lampfan rebuild. Rodelu Antique Gas Engine Discussion 1 12-09-2016 11:34:29 AM
Old dog trying to follow me home... David IN Multi-Cylinder Stationary Engines and Power Units 9 07-09-2014 09:16:59 PM
Follow your leads. Rob.S Smokstak Down Under 4 06-04-2012 08:08:08 AM
follow me dick from Ct Antique Engine Archives 5 02-03-2003 02:52:38 PM
