Welding Shop
Lincoln model unknown
this thread has 6 replies and has been viewed 3739 times
Old 11-20-2006, 05:01:35 PM
Renee Renee is offline
Default Lincoln model unknown
This past weekend I came across a Lincoln welder/generator which is buried under a pile of junk in the corner of an elderly gentlmans garage. He says it is time to part with it. It was last used about 20 years ago and at that time worked perfect. However he does not remember for sure what year it is. He thinks its about mid to early 70s and he is not sure of the model because he can not find the paper work for the unit. The unit is in very good shape but all the decals are gone exept one on the side which says "Lincoln Arc Welder". The unit is mounted on a tubular frame with about 8" or 10" wheels. It is powered with a large single cylinder Kohler engine about 18 hp. The welder/generator panel is on the end of the unit and it has in the centre a weld temp setting dial and two 110v recepitcals, one on each side of the dial. On the far right of the panel is a 220v receptical and on the bottom of the panel are the + and - teminals for the welder.
If this unit sounds familiar I would sure like to know more about it. Model and or code number. If you are familiar with this unit I would like to hear your pro's or con's also.
Thank you in advance for your reply.
Renee
Old 11-20-2006, 08:34:07 PM
JKWidener's Avatar
JKWidener JKWidener is offline
Default Re: Lincoln model unknown
what color is the kohler and what color is the welder?? it might be an old onan driven welder...the onan engines were In my book junk...And might have been replaced by the kohler..
Old 11-20-2006, 09:20:17 PM
Franz
Go to www.lincolnelectric.com
Search weldpower or weldapower probably 50 different models.
If it runs, and makes electrons it is only worth a couple hundred
Old 11-20-2006, 09:39:06 PM
The entire unit inside and out is red in color including the Kohler engine. The paint looks original.
I have been searching in the Lincoln web site of and on for the past couple days now and there are so many to look at. I may be back to have another look at the unit in about two weeks and I will probably take a picture to post with my message. That may help jog someones memory. In the mean time, when I identify the unit I will let you know.
Renee
Old 12-12-2006, 08:04:55 AM
It is a Weldan Power 150 Ac/Dc. We pulled the unit out from under the pile of junk and saw it was not in as good a shape as we had hoped. To many loose and missing bolts which could not be explained.
However, just out of curiousity, what size hp Kohler did they put on these units? It looks like a single cyl. 16hp? or maybe 18hp? The unit is from the early-mid 80s. The motor is the only untouched part.
Old 12-12-2006, 08:59:22 PM
JKWidener's Avatar
Your kohler engine on that welder is a 10 horse power kohler... here is a link to one like yours... http://groups.google.pl/group/sci.en...eade1ac7cf5d3e
Old 12-14-2006, 04:53:45 PM
Thanks jkwidener. Your right. It is a K series and I downloaded the manuals from Kohler. May offer the owner a few bucks just for the engine. It's the only part not violated.
Unknown Steam Model stevenkd5017 Scale Model Engineering 0 02-19-2019 06:59:16 PM
Unknown Model Dominiong Scale Model Engineering 10 02-20-2016 10:09:10 AM
Lincoln arc welder model DC 225/3 alyce1949 Welding Shop 6 05-25-2014 01:06:41 PM
Lincoln welder model 8927 Kpack Welding Shop 2 02-07-2013 10:04:53 AM
IHC, Unknown Model and HP, please help Evan Hale OConnor Hit & Miss Gas Engine Discussion 12 12-01-2009 11:55:32 PM
