Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator
this thread has 7 replies and has been viewed 4862 times
Old 05-25-2010, 06:02:10 PM
jeffery flynn jeffery flynn is offline
Default Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator
Were new to smokstack, but we have this old generator that we pulled out of an old factory is detroit MI. we think that it was one of the dodge brothers places where they supplied parts. We are going to post a couple of pictures to see if anyone could help us identify this generator. The generator is western electric and the engine is dodge brothers. We are missing a lot of parts on the engine and we are working on finding the missing parts. Are question is, is this generator rebuildable and who could do that in the Michigan area.
ID:	79716   Click image for larger version
ID:	79718   Click image for larger version
ID:	79719   Click image for larger version
The Following User Says Thank You to jeffery flynn For This Post:
Old 05-25-2010, 08:07:06 PM
BGunn BGunn is offline
Default Re: Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator
Well I am going to take some wild guesses here,
1. A test fixture for the engines, with no radiator or visible supports maybe they used city water for cooling.
2. A power supply for devices and parts built in plant, again no need for radiator as city water would provide cooling.
3. If it came from a Dodge Bros. plant, probably built in house so no manufacturer.
4. It has a clutch and most generators don't use them (don't need a failure when the power is out) so they may have used it as a power supply for maintenance purposes.
These are just some possibilities that you can consider unless you dig up an archive with pictures from that era.
The Following User Says Thank You to BGunn For This Post:
Old 05-25-2010, 08:26:15 PM
Thank you for the info. i guess in order to stay in line with my restoration project i will have to find a dodge radiator or something to keep it original. i realize i have my work cut out for me, but with your information i will stop looking for an image for one, because it could be hard to find.
Old 05-25-2010, 09:54:26 PM
vern0n's Avatar
vern0n vern0n is offline
Interesting. I just picked up a 1929 Plymouth engine and trans just today. Don't know what I will do with it, but I couldn't let it go to the scrapper.
The Following User Says Thank You to vern0n For This Post:
Old 05-26-2010, 02:28:18 AM
Ken Karrow Ken Karrow is offline
I am probably way off base but are you sure that it is a generator. Could it possibly be a motor that drove the engine for testing of durability or function of accessories? Would have the advantage of the engine turning with out the noise, heat, and other accessories being in the way. Just an out of the box thought. Ken
The Following User Says Thank You to Ken Karrow For This Post:
Old 05-26-2010, 06:54:11 AM
Jerry Sweet Jerry Sweet is offline
It looks like that it could be a D.C.generator,if so,it may have been used with a load grid to test,tune up or" run in" engines.If that were the case,it probably had a remote cooling and fuel system.
The Following User Says Thank You to Jerry Sweet For This Post:
Old 05-26-2010, 09:35:51 AM
vern0n's Avatar
I like Ken's idea, but I don't think that is what it is since the engine has a hand crank. No, what this is a early prototype hybrid.
Old 05-27-2010, 02:43:27 PM
Smile Re: Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator
I think it's a back up power supply, at any rate the boy's and I are going to get it working. Thanks for the replies
General Electric Generator John Merry Generators & Electric Motors General Discussion 5 02-15-2010 02:09:10 PM
onan generator electric set Daniel Sinsapaugh Small Air Cooled Gasoline Engines 3 08-05-2006 11:52:27 PM
ww II Electric Generator ruffman Generators & Electric Motors General Discussion 0 10-05-2004 02:59:01 PM
Western Electric 3 phase generator David R. Fry Generators & Electric Motors General Discussion 0 01-27-2004 01:12:43 PM
