Pioneer Gen-E-Motor (Pincor ?) Generator
this thread has 0 replies and has been viewed 3268 times
Old 04-10-2007, 02:32:12 PM
Default Pioneer Gen-E-Motor (Pincor ?) Generator
No. SS 2980 DC 2300 r.p.m. 32 volt 17.2 Amps is what I can read on the only remaining plate. It appears to also show Type T-175 but am not clear about this.
I bought this at the Elma, Washington swap meet, which was soggy but the the best swap meet I have been to yet!
This unit has been "de-militarized" unless I miss my guess. There are a bunch of rivet holes in the top of the cooling shroud that indicate that 2 separate i.d. plates have gone missing. There is olive drab under a nice newer paint job.
The engine is a one lung two stroke and uses a carburetor that has no float bowl but has a spring-loaded air inlet valve that appears to allow for engine crankcase vacuum to pull in mixed fuel through a needle valve. A Nelson take-apart muffler mounts to the top of the cylinder. Shielded spark plug and high tension wire.
It comes mounted on a plywood platform that has a plywood top box that has carring handles and clips to the mounting board with 4 latches. The top of the box has a hinged lid covering a 3 inch deep storage compartment.
Any thoughts on make, model, and original use ? I searched the archives and read every post I could find. Although I found no matches of my unit, I seem to remember seeing similar units discussed in the past.
I also received two 50 watt and one 100 watt 34 volt incandescent bulbs. Pretty cool "little" unit, runs fairly quiet, and quite smoke-free.
As always, I'd appreciate any info or comments!
Pincor Manual - Pioneer Gen-E-Motor Donald Randall Generators & Electric Motors General Discussion 87 10-17-2019 08:08:24 PM
Pincor Pioneer Gen-E-Motor Model RF35DV Shawsplace56 Generators & Electric Motors General Discussion 7 10-17-2017 06:00:29 PM
Pincor Genny SS2856 1942 Manufacture - Pioneer Gen-E-Motor ListerDiesel Military MEP and Aircraft Gen-Sets 3 05-29-2015 03:42:46 AM
Pincor Generator info needed. 16kw, Gen-E-Motor barneydog Generators & Electric Motors General Discussion 2 05-21-2009 07:52:45 PM
Pincor Motor Chris Antique Engine Archives 1 08-20-1999 08:07:18 PM
