Pincor / Gen-E-Motor Con Rod Bearings
this thread has 1 replies and has been viewed 2126 times
Old 01-16-2009, 02:30:38 PM
ListerDiesel's Avatar
Default Pincor / Gen-E-Motor Con Rod Bearings
Posted elsewhere on the 'Stak is a thread about a couple of Pincor Army Radio gensets:
http://www.smokstak.com/forum/showthread.php?t=55746
I picked up an operators manual for the Army genny from a friend, and now also have a Pincor manual for the A, AL, AG, ALA, ALB and AM engines.
Question:
Does the connecting rod have any bearing material in the big-end, or does it run direct on the crankshaft. Both engines look very similar, although of different part numbers. The Civilian engine has an Alloy rod, I don't know what material the Army genny engine has for the rod.
Any help/info would be appreciated.
Peter
Old 01-16-2009, 06:39:09 PM
John Newman, Jr.'s Avatar
Default Re: Pincor / Gen-E-Motor Con Rod Bearings
All the civilian Pincor "A" series engines I have seen have an aluminum rod with no bearing inserts.
The gen sets shown in that other thread have Pincor generator heads, but the engines are Johnson Iron Horse. It has been quite a while since I've been inside one of those Iron Horse engines and I just don't remember if they used inserts or not...
The picture below is a civilian Pincor Model ALA.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Pincor Manual - Pioneer Gen-E-Motor Donald Randall Generators & Electric Motors General Discussion 83 Today 04:19:54 PM
Pincor Genny SS2856 1942 Manufacture - Pioneer Gen-E-Motor ListerDiesel Military MEP and Aircraft Gen-Sets 3 05-29-2015 03:42:46 AM
Pioneer Gen-E-Motor (Pincor ?) Generator KidDynamo Generators & Electric Motors General Discussion 0 04-10-2007 02:32:12 PM
pincor 10k 3ph emdog Generators & Electric Motors General Discussion 2 03-06-2006 07:55:36 PM
Pincor Motor Chris Antique Engine Archives 1 08-20-1999 08:07:18 PM
