Igniter trip return spring FM H
this thread has 3 replies and has been viewed 8713 times
Old 12-31-2004, 11:22:47 AM
Gasengin Gasengin is offline
Thumbs down Igniter trip return spring FM H
I am working on a Fairbanks Morse 6 hp H. The igniter trip return spring is missing. It was a flat spring about 1/2 inch wide. I have found some flat spring material that I hope to bend to fit. My questions are does any one have a picture of this so I know how to bend the spring and what is the thickness of the spring material?
Old 12-31-2004, 11:52:38 AM
Default Re: Igniter trip return spring FM H
See if this helps.......archives search: make springs
http://home.earthlink.net/~bazillion/intro.html
Old 12-31-2004, 12:37:21 PM
Jason Jason is offline
I scanned this out of my H repair catalog. I hope you can kind of get an idea of how it's bent. Jason
Old 12-31-2004, 02:57:24 PM
Jim Tremble Jim Tremble is online now
Just a tip. After bending your spring material, pre heat your oven to 500 degrees and put the spring in the oven for one hour to releave the stress on the bent material.
After one hour, turn the oven off and let it cool to room temp. Now you can remove the spring and use it.
You can find this info in detail on the site that Kid posted.
Good Luck,
Jim
FM Ocilating Mag Return Spring DTurner Magnetos, Ignition Coils and Spark Plugs 0 01-03-2008 09:46:57 PM
Briggs H or Y - starter return spring Don Naismith Small Air Cooled Gasoline Engines 7 09-18-2007 07:19:01 PM
need a starting handle return spring for cusham 2 hp r Dave Beck Antique Gas Engine Discussion 1 06-22-2005 03:00:47 PM
Fairbanks Type H Igniter Trip Retrun Spring Gasengin Antique Gas Engine Discussion 3 01-14-2005 10:07:36 PM
Return Spring? Ryan Price Antique Engine Archives 2 04-14-2003 09:16:47 PM
