Hello and Good morning
this thread has 2 replies and has been viewed 8568 times
Old 12-31-2004, 01:31:09 PM
Randy Ghilarducci Randy Ghilarducci is offline
Question Hello and Good morning
Hello! This is my first post. I have aquired two engines and need a little help aging them. One is an Edison aircooled generator. gen frame and engine block are one casting. It has approx. a 12" flywheel, exposed valve rockers and springs, and the cooling fins on the cylinder have a metal jacket over them. Any Idea how old or value? Other engine is an inboard 4 cyl. with an in and out box on the pto end. Tag on the gearbox says Kermath sea cub. Both engines have compression and are complete with the exception of the Edison which is missing the ignition. They are of stands and are set up to run, and appear to have been restored at one time. The Kermath needs a set of points and mabey a carb build and it would run.(has electric start,gen,H2O pump, etc. The Edison is in the same shape and would probably run with the addition of a coil and a carb build. If any one has any info on age or value I would appreciate an E-Mail. Thanks Randy
Old 12-31-2004, 01:56:49 PM
Mike in NC's Avatar
Images: 74
Default Re: Hello amd Good morning
Welcome to the "Stak" Randy!! I am of no help about your engines, just wanted to welcome you to the greatest site on the web, and also to the greatest people in engine land.
SmokStak Member #28
Old 12-31-2004, 07:58:59 PM
Randy, bring up the smokstak main forum but scan on down a ways and you will find a forum for outboard and inboard engines etc. among the other topics listed. Good luck in a good hobby. Joe Morris
I went to a NJ farm auction this morning in the Paul Spence Live Auctions of Engines, Tractors and Old Iron 6 12-04-2008 11:25:55 AM
Leaving for Kinzers in the morning!!!! Allen Steam Stationary Engines, Traction Engines, Steam Boats 12 08-20-2007 10:05:08 AM
Early morning Russel Tanner Remillard Steam Stationary Engines, Traction Engines, Steam Boats 1 06-15-2007 11:26:37 AM
Good Morning from England! United info required Colin Lambert Antique Gas Engine Discussion 6 01-18-2006 01:19:07 AM
