Witte Dieselelectric Date?
this thread has 6 replies and has been viewed 922 times
Old 06-11-2018, 03:13:13 PM
Question Witte Dieselelectric Date?
I have run across a 6 HP Witte Dieseleletric plant # D-4460. Can anyone date it for me? The plant is missing the control board, The crankcase vent aand vover, and the starting crank has been busted in two. The part that goes on the crankshaft (pawl) is missing. Is a starting crank and the crankcase vent still available? Thanks in advance,
Old 06-12-2018, 11:28:26 AM
D Reachard D Reachard is offline
Default Re: Witte Dieselelectric date?
The sr.# on the engine might tell the date? I got # 80 that was built 1935. This sr# information is available on the net.
Old 06-12-2018, 03:15:56 PM
Ken Majeski's Avatar
Images: 45
I've got no D 687 I believe made in 1937.
Yours No D 4460 should have been built in 1942.
http://andrewshitnmissengines.webs.c...ialnumbers.htm
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Old 06-16-2018, 08:21:10 AM
3sverizon 3sverizon is offline
Iíve got D3629 made in 1942 itís a dieselectric plant, but the generator is long gone. Can you post pictures of your findings?
Old 06-17-2018, 11:34:07 AM
IronworkerFXR IronworkerFXR is offline
Images: 49
Andrew ,
made my own crank , I'll have to find it ,somewhere at the shop
The Following User Says Thank You to IronworkerFXR For This Post:
Old 07-10-2018, 07:21:25 PM
Default Re: Witte Dieselelectric Date?
No pictures for now - I do not have access to where the engine is - an abandoned factory complex. hopefully, it can be retrieved before the building falls down. the owner is not willing to part with it - yet.
Old 07-24-2018, 06:57:24 PM
dukeofdeeres dukeofdeeres is offline
I have a spare hand crank.
Duke
Witte KD Dieselelectric engine Andrew Mackey Vintage Diesel and Oil Engines 2 09-09-2014 09:31:50 PM
Witte 3hp date Larry Dunlap Antique Gas Engine Discussion 2 09-02-2013 12:12:54 AM
Witte date? bartlett0815 Antique Gas Engine Discussion 2 09-01-2013 09:45:03 PM
witte dieselelectric model d The motor kid pig guy Generators & Electric Motors General Discussion 1 08-01-2013 07:25:47 AM
Witte DieselElectric Chapman Generators & Electric Motors General Discussion 0 01-21-2004 07:33:02 PM
