Bernard W71 Help Needed Please
this thread has 4 replies and has been viewed 526 times
Old 07-20-2018, 01:03:15 PM
wigglingpins wigglingpins is offline
Red face Bernard W71 Help Needed Please
I have a Bernard W71 single cylinder diesel engine and I need help locating both engine oil and fuel filter numbers for this engine. Is there anyone out there that can help.. I tried posting back in 2012 but Had no response.
If any of our European friends are viewing, maybe you can help.
I would like to get this engine back up and running, but I have to service it before that is possible.
I tried a search by size, again, no results. Surely someone has to have some information on these old Bernard engines, any advise will be appreciated.
Frank
Old 07-20-2018, 01:46:24 PM
Sooty Jim Sooty Jim is offline
Default Re: Bernard W71 Help Needed PLS !!!!!
Can't help you in this case, but wanted to acknowledge that your post was seen at least. I'll keep my eyes open for info on that brand.
The Following User Says Thank You to Sooty Jim For This Post:
Old 07-22-2018, 02:29:55 AM
Oil Power Oil Power is offline
Default Re: Bernard W71 Help Needed Please
I have searched a number of filter catalogues and only found one reference to Bernard. This is in a Bosch 1972/73 catalogue. It lists Bernard Trucks, engines W31, W34, F32, T, 41. The Bosch part numbers for all these models is OIL 1 457 429 181 and FUEL 1 457 431 324. Both these filters are of the cartridge type. Does your engine have cartridge or spin on filters? If you need cartridge filters these numbers may assist. I know nothing of the Bernard engines and wonder if they may have been sold under another name. Strange how they disappeared from the filter catalogues. The W71 shows up in the Bosch injector listings. Perhaps you could give us some dimensions for the filter if you have no luck.
Hugh
Old 07-22-2018, 08:46:00 AM
cornbinder89 cornbinder89 is online now
Benard was French engine maker. Been around a long time. As to finding filters I have no secret, just a lot of time spent with filter catalogs looking thru spec's is all I can suggest.
Old 07-24-2018, 12:46:41 PM
Hugh, I did a google search on the numbers you listed for fuel filters with little luck,the oil filter numbers are promising. I'm going to have to pull the oil filter to get a size reference and go from there. Thanks for the help.
bernard-compresseur with bernard w812 drive engine Triton Antique Gas Engine Discussion 11 06-03-2011 02:50:14 PM
Bernard W42 KentuckyBoy Vintage Diesel and Oil Engines 0 12-10-2010 08:21:57 PM
The A. BERNARD Industrial Co. Denis Rouleau Antique Gas Engine Discussion 7 06-09-2010 07:56:25 PM
Bernard Dave Shaw Generators & Electric Motors General Discussion 0 02-01-2003 04:58:41 PM
Bernard A&J Oostvogels Antique Engine Archives 7 09-24-2000 04:47:12 AM
