Smokstak Down Under
Trying to identify this stationary Diesel
this thread has 7 replies and has been viewed 2053 times
Old 12-29-2009, 08:38:36 AM
Ray Bell Ray Bell is offline
Default Trying to identify this stationary Diesel
I thought I'd posted this in the right place... but no replies so it's here too:
Visiting a bloke in northern NSW, he showed me an engine he'd bought on a water pump setup and found to be siezed. That's why the pics show a lump of timber in one cylinder, he wants to clobber the piston to get it moving without damaging it.
But he's afraid he won't be able to get the parts he needs unless he knows what it is, and there are no identifying marks or brand names on any part of it.
So can anyone here help, please?
It's a 4-cyl engine perhaps 3-litres or a bit larger, I didn't measure anything.
Here are pictures:
Front with heads and pan off
Top of engine with head off (understatement personified!)
Underside showing pickup and other detail
The balance of the pics are in another post to follow.
Old 12-29-2009, 08:40:38 AM
Default Re: Trying to identify this stationary diesel
The individual heads from a couple of angles
Crank and rods from underneath.
A couple of outstanding points here. First the rods are bolts without nuts and the big ends are split at an angle. The crank looks to be fully machined and you can just see in there that there's a bolt with some kind of caps on the main bearing centre. Maybe a facility for cleaning the oil galleries?
Main bearing caps are huge and stamped with numbers, they have castellated nuts with split pins.
Finally, the valve covers.
Even guesses will be taken at this stage, if he gets it to turn over (it's been out in the weather a while) he might need gaskets (head gaskets are copper) or something.
Thanks in advance for any help.
Old 12-29-2009, 10:06:51 AM
Ironsides Ironsides is offline
Ray,she doesn't look too bad at first peek.Before the owner starts hammering that piece of wood may I suggest that he removes the big end caps and sees if it is crank siezed or bore siezed!From what I can see on your photos there is some bore glazing in the centre pair of cylinders but no obvious broken bits.Also check that the starter has not jammed on the ring gear.Is the cam gear free.That should give him a bit of a lead in,please keep us in the loop,Norm
Old 12-29-2009, 11:12:21 AM
Wayne Riedlinger Wayne Riedlinger is offline
That engine has some similarities to a KT series Cummins. Maybe an early version of it. I have never seen a 4 cylinder one though.
Old 12-29-2009, 04:09:16 PM
Heller D. Davis Heller D. Davis is offline
I would recomend that you put a steel plate under that stick of wood before you pound on it. One that covers the top of the piston so as to not knock a hole in the piston.....My 2cents worth....Happy New Year All
Old 12-29-2009, 07:54:18 PM
Is it threaded with metric? US? or ??
Old 12-29-2009, 08:57:14 PM
oldtool53 oldtool53 is offline
Hi,
Look for any numbers stamped on the fuel injector bodies. Also any info on the injection pump tag may help. Let me know and I will look them up for you and maybe identify what you have there.
Mark
Old 02-01-2010, 11:12:49 PM
Teddey Teddey is offline
Ray, Did you ever get a confirmed identification of the diesel?
Teddey
Can anyone identify this stationary Diesel? Ray Bell Smokstak Down Under 2 12-26-2009 07:26:32 AM
Identify 2 cylinder diesel torocon Vintage Diesel and Oil Stationary Engines 14 03-13-2009 09:02:01 AM
Can anyone identify this stationary gas engine? BPumphrey Unidentified Engines 16 01-31-2009 02:05:23 AM
My first stationary diesel: Lister-Petter HR3 Alyssa Vintage Diesel and Oil Stationary Engines 0 09-30-2008 05:54:26 PM
Help-identify this Diesel erayhardy Vintage Diesel and Oil Stationary Engines 7 02-28-2008 01:55:11 AM
