Smokstak Down Under
Unusual Burner
this thread has 5 replies and has been viewed 1916 times
Old 01-27-2010, 05:50:17 AM
David Nicolson David Nicolson is offline
Question Unusual Burner
Hi All, hoping some one can shed some light on what this burner was originally used on,i picked it up at a sale last weekend,i asked the owner and he said i was of a lanz bulldog tractor and also blackstone used them{ this i doubt very much},cheers dave
ID:	72426   Click image for larger version
Old 01-27-2010, 08:11:09 AM
Wayne Timms Wayne Timms is offline
Default Re: unusual burner
Hi Dave,
I don't know what it is but I don't understand the 2 fittings?
Is it possible that the fuel moves on to serve another purpose?
If yes, then this would be a continuous lamp.
Regards,
Wayne
www.bluefuel-whitesmoke.com
The Following User Says Thank You to Wayne Timms For This Post:
Old 01-27-2010, 10:55:23 AM
Boatbum's Avatar
Boatbum Boatbum is offline
Default Re: Unusual Burner
I'm thinking the second connection was for compressed air. Hot bulb marine engines burners worked this way.
The Following 2 Users Say Thank You to Boatbum For This Post:
Old 01-27-2010, 08:07:01 PM
Hi wayne and boatbum, my thoughts are pretty much the same as boatbum as to the second outlet,one for the fuel for the lamp and one for air,the burner is 4 1/2in tall and the arm 16in long which makes me think it is off a horizontal continuous lamp engine,do you think it will be possible just to run gas through it to start an engine,cheers dave
Old 01-27-2010, 11:59:23 PM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
The extra fitting could have been where a needle valve went in. A packing gland could have been screwed onto that nipple.
Eric
The Following User Says Thank You to Eric Schulz For This Post:
Old 01-28-2010, 05:16:20 AM
Hi eric, thanks for the thought, i have just cleaned both inlet holes out and they are seperate holes,the one facing upwards in the photo is the jet hole and the other comes out below and off to the side of the jet,no threads in fuel hole,so it seems that air possibly went through the lower hole,cheers dave
Fairbanks burner assembly Gary Springer Hit & Miss Gas Engine Discussion 0 06-03-2008 09:20:19 PM
oil Burner Brian Manning Steam Stationary Engines, Traction Engines 22 11-20-2005 12:17:39 PM
Advance straw burner LundMachineWorks Steam Stationary Engines, Traction Engines 2 08-30-2005 11:18:22 AM
BURNER ASSEMBLY Dan Burkart Antique Engine Archives 0 02-06-2001 10:07:50 PM
hot tube burner larry harding Antique Engine Archives 0 01-31-2001 10:55:21 PM
