Smokstak Down Under
Harland water pump SSA 3/4"
this thread has 1 replies and has been viewed 2477 times
Old 02-04-2010, 02:20:41 AM
cobbadog cobbadog is offline
Default Harland water pump SSA 3/4"
Can anyone help date this pump and offer some details as to what RPM and pressure it should work at?
Name:	Impellor and flat belt pulley.jpg
ID:	72951   Click image for larger version
Name:	Impellor cover.jpg
ID:	72952   Click image for larger version
Name:	Main Body 218   3.jpg
Old 02-04-2010, 06:40:38 AM
Rusty Engines Rusty Engines is offline
eMail NOT Working
Default Re: Harland water pump SSA 3/4"
Hi cobbadog
Southern Cross made a pump that looks the same but is one inch outlet size and the charts read
Gallons per Minute 10 RPM 800
GPM 15. RPM 815
GPM 20. RPM 825
GPM 30. RPM 875
GPM 40. Rpm 1000
So yours being only ¾” will a little bit less in GPM
The SC pump was made in 1959
Ian
F-M "Typhoon" water pump Rick Strobel Hit & Miss Gas Engine Discussion 7 10-08-2011 12:19:39 PM
Anyone hear of the "Backus Water Motor Company"? Ned L Hit & Miss Gas Engine Discussion 25 12-13-2007 09:17:19 AM
Behavior of water and its ability to "Conduct" heat Andre Blanchard Steam Stationary Engines, Traction Engines 9 11-13-2005 05:17:28 PM
Novo "Rollr"..Plugged water jackets Rick Strobel Antique Engine Archives 0 08-28-2002 10:07:58 AM
Lucas water pump "PRESSURE" Relief Paul Spence Antique Engine Archives 4 08-30-2001 06:40:08 PM
