4A032 Carb float or replacement carb
this thread has 7 replies and has been viewed 327 times
Old 03-05-2019, 02:14:48 PM
Steelart99 Steelart99 is offline
Default 4A032 Carb float or replacement carb
The 4A032 engines have always had carb issues when used with ethanol gas. Over the years, there have been various replacement floats and float mods done, but from what I've read, no replacements are still available. I have not seen any solutions poised in several years.
So, has anyone come up with an available replacement carb, or a brass replacement float for these engines?
Old 03-05-2019, 04:49:39 PM
miltruck miltruck is offline
Default Re: 4A032 Carb float or replacement carb
All three of the little military engines use the same carburetor; the 1a08. 2a016 and the 4a032. The carbs are no where to be found and the military never had any individual parts made for them. They expected if there was a carb problem the whole unit would be changed out.
Some people on this site have coated the floats with gas tank sealer which I understand does work, but I would be afraid of the weight change. Best thing I have found is to run the engine totally out of gas by shutting the fuel off @ the tank every time you run. Been doing that with our 3 units and no problems yet with the floats.
Saturn used to have carbs, but I believe they are all gone and Saturn just is selling on e-bay now, not their store anymore.
Good luck.
Old 03-05-2019, 09:53:18 PM
Good luck.
I'd seen that Saturn did not have carbs anymore, and I'm hesitant to just coat the float for the reason you stated. The more I've read, the more it seems like the best solution might be to simply replace the carb with a different one and work out the linkages. Thanks
Old 03-05-2019, 10:44:34 PM
try colemans surplus for a carb
Old 03-06-2019, 12:27:39 AM
Will do. thanks for the lead
Old 03-06-2019, 11:02:57 AM
gnucklehead gnucklehead is offline
If you do find a carb from military surplus, it will most likely have the same plastic-coated foam float. Best bet is to find an old chainsaw or something with a Tillotson that has a metal float. I've been seeing some black plastic MD floats on fleaBay, may be for alcohol fuels, I dunno I'm interested to hear if anyone has used the black ones.
Old 03-06-2019, 11:11:40 AM
I certainly don't want to get a replacement that has the same issue! I'm looking for a carb that someone has used sucessfully.
Old 03-07-2019, 06:47:24 AM
mdlbldrmatt135 mdlbldrmatt135 is offline
I have coated the float successfully.
I used model airplane Dope. I was made by Midwest products. It's getting harder and harder to find. I also have one coated in Redkote that I didn't get around to testing last year, hopefully this spring.
The weight added wasn't much, and I didn't notice any weird effects. I will note, that there are Brass floats out there in some carbs, my 4a032 on my MEP-016A has one, and I got it straight from Gov't Liquidation.
MEP 1A08, 2A016, 4A032 Engines: Carb Float Brass Replacements miltruck Military MEP and Aircraft Gen-Sets 2 08-31-2018 04:02:39 PM
4a032/2a016 ethanol proof carb upgrade sorenson2009 Military MEP and Aircraft Gen-Sets 11 03-25-2016 04:30:47 PM
4A032 carb question kyleaudio Military MEP and Aircraft Gen-Sets 5 04-28-2013 01:01:56 PM
4a032/2a016 Tecumseh carb swap sorenson2009 Military MEP and Aircraft Gen-Sets 1 03-20-2013 01:43:18 PM
4A032-2 3KW generator gas carb reassembly problem. Runnin Green Military MEP and Aircraft Gen-Sets 4 10-10-2012 10:38:47 PM
