B&S L-head engine - Suggestions for oil level checking in non-OEM configuration
this thread has 12 replies and has been viewed 561 times
Old 02-13-2019, 03:45:09 PM
armandh armandh is offline
Default Re: B&S L-head engine - Suggestions for oil level checking in non-OEM configuration
shorten the dipstick and tube equally
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 02-13-2019, 09:51:12 PM
Originally Posted by bsf View Post
Funnel w/ extension tube into original fill port.
If I made my own dipstick/plug, what diameter rod should I use? Material? Any concerns with a 6” – 7” dipstick not mostly surrounded by a tube or tubular passage?
I've used 3/16 brass brazing rod. its rigid enough to not move around and easy enough to get a solid mount in the plug fitting. as I said earlier. drill a 3/16 thru hole and press the rod thru the hole. Make sure the engine is full with the original stick then when your fabbed stick goes in just mark the oil level with a file.
Old 02-14-2019, 02:56:56 PM
bsf bsf is offline
slip knot,
I believe the port is 3/8” NPT, not ½”. However, I was looking at fittings yesterday. I intend to fab one with 3/16” brass rod; either a 3/8” MIP x ¼” pneumatic male nipple or hose bare adapter; and O-ring. I think ID of ¼” pneumatic nipple or barb is a few thousands less than 3/16”, and I have or have free access to those materials. Additionally, I may be able to use the nipple or barb to make some sort of grip for tool-free tightening/loosening. Thanks for the advice. Your general idea should work.
Diesel engine suggestions pswired Generators & Electric Motors General Discussion 11 03-25-2015 10:05:57 PM
Vertical Blackstone 4 HP checking oil level junction 28 Smokstak Down Under 5 02-17-2011 03:19:10 PM
Suggestions for big engine skids Brian D. Antique Gas Engine Discussion 6 06-11-2007 12:29:56 AM
Suggestions needed for engine to buy... RobDavis29 Antique Gas Engine Discussion 9 09-29-2006 11:52:01 AM
