1959 Kenworth Chain Drive
this thread has 9 replies and has been viewed 804 times
Old 02-27-2019, 11:57:11 PM
Default 1959 Kenworth Chain Drive
I had no idea that the chain drive concept for heavy hauling motive power was still a valid concept in 1959. Big off road logging truck.
https://www.youtube.com/watch?v=rwfbxT3JvXU
The Following 8 Users Say Thank You to Mark Schneider For This Post:
Old 02-28-2019, 01:13:29 AM
Vanman Vanman is offline
Default Re: 1959 Kenworth Chain Drive
Wow, neat! Is that an NH Cummins? Mine looks similar, somewhat different intake manifold?
My 1955 Crown originally had a "Silent Drive" to the second axle, but the sheaves and belts are long gone.
https://silentdrive.com/our-company/
Keith
The Following 2 Users Say Thank You to Vanman For This Post:
Old 02-28-2019, 01:14:27 AM
Oldskooltruckn65 Oldskooltruckn65 is offline
New wrinkle in my horn for sure.
Old 02-28-2019, 01:45:46 AM
K-Tron K-Tron is offline
Keith, I have heard the term "Gates Rubber Band Drive" to describe the belt driven pusher axle. A friend of mine collects chain drive Sterlings. They are really neat trucks. I love everything about chain drive, and hope to one day have a chain driven truck. An M26 Dragon Wagon with a 440 Hall-Scott would be nice, but I could settle for an AC Mack
Chris
The Following 3 Users Say Thank You to K-Tron For This Post:
Old 02-28-2019, 02:27:39 AM
International Harvester used the Belt drive as well. From my Library.....
ID:	329625   Click image for larger version
The Following 5 Users Say Thank You to Oldskooltruckn65 For This Post:
Old 02-28-2019, 07:55:16 AM
I remember those rubber band drives as a kid. My family is from Iowa and an uncle cursed the things. He said they didn't do anything but slip and when the belt broke it could lock up a wheel.
Last edited by I like oldstuff; 03-01-2019 at 08:25:17 AM. Reason: Mr. sausagefingers can't type.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Old 02-28-2019, 04:06:38 PM
Monsonmotors Monsonmotors is offline
Looks like a worm-drive differential?
Old 02-28-2019, 04:55:59 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Originally Posted by I like oldstuff View Post
I remember those rubber band drives as a kid. M family is from Iowa and an uncle cursed the things. He said they didn't do anything but slip and when the belt broke it could lock up a wheel.
try fixing a flat on the inside rear tandem!! i used to service one of those
restoring old iron, hot air engines and modelmaker.
The Following 2 Users Say Thank You to Marv in Minn For This Post:
Old 03-01-2019, 03:31:38 PM
The differential doesn't have the signature bearing cover of the worm drive set up on the back side so more than likely this is a double-reduction unit. There is yet another reduction gained on the chain sprockets so this thing is geared in the basement. Probably never saw speeds much above 30 mph.
The water tank referenced to which is mounted behind the cab holds 300+ gallons of water and was used for brake cooling.
Advantages of this chain drive set up would be added clearance and positive driving action of the tires on a given side. Differential action would still be needed for corners.
Name:	worm drive 1.jpg
ID:	329668   Click image for larger version
Name:	worm drive 2.jpg
The Following User Says Thank You to Mark Schneider For This Post:
Old 03-01-2019, 07:25:38 PM
Heins Heins is offline
Here are two pictures of a double reduction axle.
ID:	329683   Click image for larger version
The Following 3 Users Say Thank You to Heins For This Post:
IHC Drive chain Butch Howe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 04-14-2017 02:46:01 PM
Mogul 8/16 drive chain Kevin Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-15-2014 08:53:39 AM
Fairbanks H with chain drive mag J Eddy Antique Gas Engine Discussion 6 07-12-2013 09:42:09 PM
Drive Chain for old seeder mecoastie Farm + Industrial Antiques and Collectibles 8 10-01-2011 04:49:50 PM
Bolens Drive Chain Pat in Mississippi Antique Engine Archives 0 03-27-2003 04:15:26 PM
