Bell Housing Help Needed
this thread has 6 replies and has been viewed 619 times
Old 03-03-2019, 10:42:51 PM
Hubbie Hubbie is offline
Default Bell Housing Help Needed
After surfing the web most of the day in search of a comparable engine, I can't find an engine with the correct bellhousing. I'm thing of using a Hercules, Cummings, or Waukesha. Either gas or diesel. The problem I'm having is the original engine is a sae 1 bellhousing and can't find a source that lists the sae number for the new engine. Does anyone know if a list is available? I have ruled out the 5.9 Cummings as it is a sae 3.
The reason I want to reuse the original trans is the brake and clutch pedals are mounted to the plate that is between the bellhousing and the trans. Thanks in advance. Mike
Old 03-03-2019, 11:23:04 PM
Jack Innes Jack Innes is offline
Default Re: Help needed
Have you thought of an adaptor plate?
https://www.hayescouplings.com/produ...sing-adapters/
Old 03-05-2019, 01:37:57 AM
K-Tron K-Tron is offline
Mike, What vehicle are you working on? what is the original engine? Detroit Diesel made several two stroke diesels with SAE #1 flywheel housings. About the smallest that you can use in automotive application would be a 4-71. With a turbocharger it could be comparable to a 5.9 Cummins. Waukesha certainly built automotive engines that could be had with SAE #1 flywheel housings. The 817 cubic inch engine found in several fire trucks comes to mind. I have seen SAE adapters used before, but usually they are to adapt a smaller transmission bellhousing to a larger flywheel housing, not the other way around. I am curious what transmission you have that is SAE #1. Is it an old Brown Lipe?
Chris
Old 03-05-2019, 06:25:03 AM
K-tron, I'm working on a 28 Gramm with a continental 15h 6 cylinder and a fuller ru-16 transmission.
Old 03-19-2019, 08:30:39 PM
cornbinder89 cornbinder89 is offline
Default Re: Bell Housing Help Needed
Most gas and many medium diesels (even the 6-71) used #2. Big Bore diesels use #1. Many can be had with a range of sizes but one particular size is most common and finding the odd size is hard.
Old 03-19-2019, 11:56:46 PM
A 30 McCord catalog lists Cont'l 14H/HA, 15H and 16H with the same gasket set, incl ONE 6 cyl head gasket, the 16H shown as 43/4x53/4....
A 42 McCord catalog doesn't list the 14H/HA or the 15H; it does list the 16H, again as 43/4x53/4, BUT with TWO head gaskets (pairs of three)...=
NOR DO the individual gaskets listed match any of the 1930 gaskets listed...(???)...
However, the latter 16H is also the Brockway 36B...worth a call to the Brockway Club to see if they have an engine, and, if so, compatible??
Old 03-20-2019, 05:56:43 AM
Thanks Bud, I'll try them. Mike
Kohler 10RY Thermostat Housing Part Needed Birken Vogt Kohler Generators 6 01-27-2017 11:20:51 PM
Info needed for Robert Bell Portable Colin Farquhar Steam Stationary Engines, Traction Engines 8 11-23-2014 12:30:11 PM
Deere B fan housing. jmholland Antique Farm Tractors 1 03-28-2014 08:38:11 AM
SAE Bell Housing Information richardsonsf Machine Shop and Tool Talk 2 01-03-2013 01:40:34 PM
Continental F163 bell housing help jdog Multi-Cylinder Stationary Engines and Power Units 8 02-22-2011 11:53:39 PM
