Waukesha Engine information needed
this thread has 5 replies and has been viewed 472 times
Old 03-12-2019, 01:59:01 PM
Alan D. Alan D. is offline
Default Waukesha Engine information needed
Does anyone here have good information, or practical experience, on the Waukesha RB 6 cylinder engines? I am aware that this engine was built in early 1930's but when production stopped I do not know. If you have information on applications, numbers built, similarity to other series to share parts and etc. I would greatly appreciate that information. I do have an early Motor Repair manual that gives a few basic bits of information but not a lot. Drop a note if you can help.
Al
Old 03-12-2019, 02:27:05 PM
Default Re: Waukesha Engine information needed
Attention Craig A...Did you ever get this Waukesha PDF thing figured out? I would be interested in some of this information also.
https://www.smokstak.com/forum/showthread.php?t=101480
Another place for information is the Waukesha Engine Historical Society. I have had recent contact with them on a different motor. Some engine information is archived and takes awhile to retrieve. Currently staffed by a very personable volunteer. Can be contacted here:
www.wehs.net
A 6RB176 fire truck engine on ebay...tag reads 1936 build date on this one.
https://www.ebay.com/itm/Fire-Truck-...sAAOSwIQdZMYnV
Old 03-13-2019, 01:55:43 PM
I have an old undated page listing 6RB and 6RBR (also in your Motor) apparently from three catalogs listing:
Autocar, Available, Corbitt, Diamond T, Fageol, FWD, Grass-Premier, Guilder, Hahn, Hendrickson, Hug, LaFrance-Republic, Le Moon, Moreland, Oneida, Sterling, Walter, Ward LaFrance and WMC bus, too many models to list: I'm sure that's not a complete list...
WEHS can give you production dates and numbers; looks like into 5T to 15T models thru the 30"s into 40/41, but I only eyeballed a few that listed years...
A 36 catalog indicates it's own piston assembly...valves, guides, springs shared with 6AB, 6AL and 6HB... rod/main bearings shared with 6AB, 6HB and 6QB...
The Following 2 Users Say Thank You to Bud Tierney For This Post:
Old 03-14-2019, 11:37:03 AM
Bud, Thanks for your response. I have tried but to date I sure have a problem with the numbering system used by Waukesha for their wide variety of engines. I even have a hard time following the basic series of engines let alone all of the derivatives. I would like to learn more. The Waukesha site is good but I would need and interpreter to help me study and follow along.
Al
Old 03-14-2019, 02:45:41 PM
There's a Waukesha production book---someone on this site had one several years ago---but they're apparently now considered proprietary, as WEHS will not sell copies...
One comes up occasionally on EBay or the other book sites---Abebooks, Amazon, AutoLit (if you care to spend the very most, but (sigh) they have stuff no one else has) etc...
Wauks a little odd---but not nuch---in their engine ID designations...like most, they started with A to Z, with a few 4-number and 6-numbers (cyl/hp) when transitioning to the 6-production...
Your 6RB (the correct designation) may/should? have a number following, which would be the works code for accessories (carb/ign, etc) on your particular engine, altho they may've sold an pff-the-shelf model with "standard" factory qaccessories they felt needed no special ID'ing...
They do seem to be a tangle at first; I don't follow modern engines, but believe they're just heavy industrial now...
Old 03-18-2019, 05:00:32 PM
Hello Bud, Thanks for your response and information.
Al
Kohler with Waukesha & Big Generator Information needed (5E61) Jim Martin Generators & Electric Motors General Discussion 5 07-02-2012 01:41:13 PM
Information on Waukesha F.C. 9G engine. Jim Henthorn Multi-Cylinder Stationary Engines and Power Units 2 04-30-2010 10:37:41 PM
Alamo Engine Information Needed trashman6062 Antique Gas Engine Discussion 3 08-30-2009 09:01:57 PM
Waukesha information? d19klem Multi-Cylinder Stationary Engines and Power Units 1 03-09-2008 11:51:04 PM
Information wanted on Climax Engineering with Waukesha Doug Shepherd Generators & Electric Motors General Discussion 6 11-28-2007 01:57:38 AM
