Welding Shop
Need help choosing a welder
this thread has 19 replies and has been viewed 4373 times
Old 03-14-2008, 04:56:56 AM
beeman
Default Need help choosing a welder
Hello friends,
I need to find a welder to suit my needs. I have a small farming operation with a 80hp tractor and implaments. Most of the time I either snap something off or need to fabricate something on an existing piece. I never need to weld anything larger than 1" thick. Probably 1/8" is the smallest that I would need to weld. About once a month I find myself visiting my friend at the local machine shop and I'm afraid that I'm going to wear out the welcome mat. He has a big Esab. What is an affordable welder that I can use for my needs? I have Oxygen/Acetylene cutting/rosebud setup. Does brazing do the job or would I be better off with an electric welder? Thanks much and have a nice day.
Old 03-14-2008, 05:05:23 AM
JKWidener JKWidener is offline
Images: 26
Default Re: Need help choosing a welder
I have a Miller Matic 250 wire feed welder, welds anything i have done.
Old 03-14-2008, 06:07:39 AM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
I use an ESAB 250 and it is perfect for my needs.
Old 03-14-2008, 08:15:42 AM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
Mig / wire feed welders are wonderful machines for thin to average thickness metal, say 1/8-3/8 even 1/2 I've owned a Miller 200 amp machine since the early 80's and life wouldn't be the same without it. I also believe there is a place and time for Migs and then a place and time for stick welding..
If you decide to go Mig you might want to consider useing Flux core wire.. In farm applications the rust, oil and grease that we need to work around is not cover gas friendly and your welds will be less than good.. you will also eliminate the need for a tank and reg. I've seen many flux core equiped machines on the farms I visited while in the dealorship.
If you want a " do everything machine" something like a Miller Shop Master 300 with a wire drive on top gets my vote but the cost can be a little steep for now and then repairs.
Just my observations. Hope this helps.
Randy Hart Ohio
Old 03-14-2008, 08:26:40 AM
TommyA5 TommyA5 is offline
I started out with a Hobart AC/DC Stickmate. I bought it to work on my tractor and implements as well. With stick welding you can use many different rods that better suit the welding application needed at the time. This is especially helpful with the rusty dirty metal. You will find the AC machines are cheaper but the DC is nicer to use.
Old 03-14-2008, 08:56:40 AM
K D Redd K D Redd is offline
The Lincoln "Buzz Boxes" like picture at the top of this thread might be a place to start. I think the one picture is the AC/DC version. The AC only one is relativly cheap and would let you get your feet wet. They are no the beat welder on the market but they are better than nothing. An AC buzz box and 6011 rod is hard to beat on rusty greasy metal. Used one for years until I bought a Miller 200 with Spoolgun. If you do chose a Mig type I agee you should think about Flux Core capability.
Kent
Old 06-02-2009, 04:17:56 PM
tstory422 tstory422 is offline
Iam 70yr's old been welding 50yr's J H Foster hit the nail on the head. That little red Lincoln will do the trick,but knowing what know I would try for an ac dc even used. You will learn to weld on what ever you get. Iwould go with stick
Old 06-12-2009, 12:20:09 PM
mrxlh mrxlh is offline
Biggest question is how much do you have to spend? A lincoln, miller or hobart cracker box ac/dc would probably meet your evey need. However if you plan on any projects in the future, a mig might be nice. I would definately get a DC version. You have many more rod choices.
Old 06-12-2009, 10:24:55 PM
Motormowers's Avatar
I have been welding with those AC Lincoln buzz boxes for the last 20 years and love them. They take a beating and are dirt cheap at Home Depot. The AC welders cut through rust better than DC and for farm work I wouldnt think weld beads need be that pretty. You can still put a nice bead down with AC too. I like to use the 7014 rods for general purpose. If youre ever going to weld tin or stamped sheet steel then a MIG would be better.
Old 06-12-2009, 10:57:35 PM
AC welders do not and will never "dig" as good as a DC machine. No AWS or ASME coded vessel is welded with an AC machine. Not that an AC machine will not work, you just have a much better selection and welding options with a DC machine.
Mig welder Chris Page Welding Shop 8 03-23-2008 12:14:49 PM
Choosing what to collect Mac Leod Antique Gas Engine Discussion 15 02-16-2008 07:20:59 AM
Need old mig welder help!!! CAnger Welding Shop 1 11-19-2006 06:45:12 PM
blackhawk welder CAnger Welding Shop 3 04-07-2006 12:04:53 AM
gen/welder Tim(PA) Generators & Electric Motors General Discussion 4 03-19-2006 02:13:28 AM
