Oil Field Engines
Anyone seen a bessemer like this?
this thread has 3 replies and has been viewed 4081 times
Old 03-27-2006, 07:00:17 PM
Zach Williams's Avatar
Zach Williams Zach Williams is offline
Default Anyone seen a bessemer like this?
This bessemer looks more or less like a regular bessemer except it doesnt have chain oilers and there seems to be no holes for a tag on the base and the Bessemer logo is different then anything i have seen before.
Instead of reading The Bessemer Grove City Pa it just says Bessemer.
Here is a photo:
Any thoughts on how many of this style are around?
I will get more photos when i get back home, its out now but didnt have the camera with me to get a better shot.
Old 03-27-2006, 11:58:46 PM
Default Re: Anyone seen a bessemer like this?
and i also should have mentioned there is no raised line surrounding the Bessemer unlike some bessemers that just have Bessemer on them
which i guess is evident in the picture
Old 03-28-2006, 12:08:14 AM
also another feature,
the crosshead slides sit on the top of the engine base and are not sunk in the base,
the crosshead looks more like an oilcity crosshead than a bessemer crosshead,
if you look in the picture on the top left you can see the crosshead slide and spacer at the top of the bedplate,
Old 03-28-2006, 01:42:45 AM
possible conversion cylender for a 'half breed engine?
Bessemer ... dmstephens Unidentified Engines 0 04-01-2013 08:23:59 PM
Bessemer Keven Withers Oil Field Engines & Related Equipment 6 11-19-2010 08:58:15 PM
25 hp Bessemer JIMnWV Oil Field Engines & Related Equipment 0 04-05-2010 08:55:51 AM
5 hp Bessemer HVFD FireFighter Oil Field Engines & Related Equipment 15 11-17-2009 05:49:02 PM
bessemer???? Dan Grace Oil Field Engines & Related Equipment 3 08-14-2006 04:32:17 PM
