Oil Field Engines
5 hp Bessemer
this thread has 2 replies and has been viewed 1315 times
Old 07-09-2009, 01:50:26 PM
HVFD FireFighter HVFD FireFighter is offline
Default 5 hp Bessemer
I purchased a hot tube, burner, and chimney, thanks John. The chimney needs to be drilled to match the holes on the engine. QUESTION, on the bottom of the chimney there are four protrusions, they are bigger thean the circumfrence of the opening on the engine, so it does not allow the chimney to sit flush over the mount, there is about 1/4" gap. does the chimney need to fit tight or is it suppose to sit up a little to let in air? should I grind the four protrusions off to make it sit flush then bolt it on?
Old 07-09-2009, 03:39:41 PM
Doug Waggonner's Avatar
Default Re: 5 hp Bessemer
I should fit flush against the head.
Old 07-09-2009, 06:29:33 PM
John Burns John Burns is offline
They are sapposed to keep the chimney up off the head to allow for air intake.
John
5hp Bessemer HVFD FireFighter Oil Field Engines & Related Equipment 2 07-09-2009 01:43:42 PM
25 hp bessemer JunkmanIH660 Hit & Miss Gas Engine Discussion 4 09-29-2007 07:39:29 PM
Need Help With 5 Hp Bessemer fireman Hit & Miss Gas Engine Discussion 2 06-29-2006 10:12:20 AM
Bessemer Lyle Fall Oil Field Engines & Related Equipment 0 05-15-2006 12:31:56 PM
Bessemer Help dave in PA Antique Engine Archives 1 05-20-2002 11:40:59 AM
