Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Majestic Cedar Washing Machine
this thread has 15 replies and has been viewed 2708 times
Old 07-01-2016, 04:07:33 PM
HermitFlywheel HermitFlywheel is offline
Default Re: Majestic Cedar Washing Machine
So I've been busy with other projects, started taking it apart. I wanted to replace every bolt and nail. Well disaster struck. Luckily I have a spare head and crank that are a different agitator head, but same gears and crank. I'll repurpose the spare crank into a butter churn or something.
So word to others, leave these carriage bolts in if you can
Old 07-01-2016, 08:30:24 PM
I would not use epoxy, the wood won't be able to breathe. I would just clean the wood and use either linseed or Tung oil.
Old 07-02-2016, 01:31:46 PM
Yeah it's clear I need to put alittle oiling maintenance on the tub. I'm just getting lazy in my old age. No permanent seal on wood is the verdict. But it looks like someone put some kind of hard clear on the tub before me?
So I'm in agreement with everyone oil is the way to go. But I gotta ask, linseed(non-boiled is food safe I think), and a possible mix with turpentine, or just tung oil, has anyone actually washed clothes in their tub recently? No skin irritation from oils seeping into washed clothing?
Let's say linseed oil, turpentine, and tung oil would be difficult to acquire where you live. What other oils could you use? Hemp oil?vegitable oil?
Old 07-02-2016, 08:50:22 PM
If you use a couple of thin coats of boiled linseed oil it will harden and will not bleed into clothing. I would not use raw linseed oil as it stays tacky for a long time. You can also get linseed oil based varnish which would give you a hard finish, I got some from here, http://www.solventfreepaint.com/linseed_paint.htm
Old 07-04-2016, 12:36:21 PM
Bill I checked out that linseed paint. I like the idea of that, but I'd like to keep the black lettering on outside, but the inside of tub may be a good place to use that linseed paint.
Old 09-19-2016, 08:37:47 PM
Some more progress.
Re-made the agitator as the old was smoked. But I glued old agitator back together, cut rusty carriage bolts, I'll make a candle holder or something out of it.
I've been avoiding taking the tub apart since I'll need some free space.
Almost everything is sandblasted and primed for paint. The top plate holding wood agitator is out to cerakote, since it was super cheap.
The original shaft was smoked. Whipped up a new one out of 304. Fits great.
Anybody ever seen a B&S WM on a washing machine? Meco3hp Antique Washing Machines 17 12-11-2013 01:25:02 PM
Washing machine. Sammy Antique Washing Machines 4 04-22-2013 10:14:28 AM
Maytag washing machine John Savot Antique Washing Machines 3 01-11-2013 11:27:23 AM
Washing Machine? Andrew Albrecht Antique Washing Machines 10 01-14-2006 07:25:06 PM
Maytag Washing Machine Help Please Joe A Maytag Engine Collectibles 2 04-19-2003 08:00:41 PM
