Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Easy Washer Info Needed
this thread has 4 replies and has been viewed 1611 times
Old 09-24-2017, 05:26:20 PM
shiftlessguy shiftlessguy is offline
Default Easy Washer Info Needed
Picked up an easy motor engine # 19735 that has pit metal flywheel
A broken carb of course,no kick start(may rig a rope start).Gotter pretty much apart but stopped for now as I'm into timing gears.I noticed a mark on each gear that never line up so either it was timed wrong or.I have a book but it doesn't get into engine to any detail.Can anyone PDF me a better manual.Engine seems to be in good overall condition.Thanks in advance
Old 09-24-2017, 06:33:45 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 14
Default Re: easy info needed
Good luck trying to get a manual they are scarce.
Old 09-24-2017, 06:49:56 PM
turbo's Avatar
turbo turbo is offline
I don't think you will have much luck finding a manual and if you do it probably won't have to info you are looking for anyway. Time it without the marks. The exhaust valve should close just before TDC and open just before BDC.
Old 09-25-2017, 09:00:12 AM
Default Re: Easy Washer Info Needed
Guess ill make my own timing marks just to make it easier.I'll assume the small flex tube goin to carb is crankcase is a breather kinda innovative for the time period.I see why all the carbs break on these with the way its hooked up,lotta vibes there.I plan on adapting a Briggs wmb carb and mounting tank.I was hopin to fix carb but too many broken pieces and findin a good carb is pretty rare,ya it wont be OEM but it'll run,I think
---------- Post added at 08:00:12 AM ---------- Previous post was at 07:59:10 AM ----------
Any model year numbers out there?
Old 09-26-2017, 01:10:54 AM
Gotter all apart today its in good shape.Musta been bored at one time as piston says .20.Gotta address the lower connecting rod bearing as there's abit of play there and polish up bearing surfaces.Wrist pins in good shape though.I did find a casting date on'er "29".Made my own timing marks as the ones there didn't mate at the rite place.Took my dremel and ground off one of the marks.Checked it a few times to make sure it worked out each time.
Easy Washer Engine Ken Karrow Antique Washing Machines 3 09-17-2017 10:42:39 PM
R&V easy cooler info needed Bryant Antique Gas Engine Discussion 11 03-21-2017 09:32:18 PM
Easy Washing Machine Engine info needed. Tim Venetis Small Air Cooled Gasoline Engines 14 12-31-2015 01:44:36 PM
Easy Washer Engine Junkologist Small Air Cooled Gasoline Engines 10 09-01-2009 09:01:04 PM
Easy Washer R Information needed! Robert Green Small Air Cooled Gasoline Engines 0 07-11-2009 08:57:28 PM
