ILO (JLO) 2 Cycle Diesel Engine
this thread has 11 replies and has been viewed 1099 times
Old 09-02-2018, 09:36:58 PM
Junkologist's Avatar
Images: 160
Default Re: ILO (JLO) 2 Cycle Diesel Engine
I finally had some time to dig into this engine today. Found a bleeder screw down by the injection pump. Opened it and air bubbles started coming out and then just fuel. Closed it up and then I could hear the injector working when rolling the engine over. Two pulls later on the rope and it was running! Didnít use a starting wick either.
This engine has a dipstick and I was really puzzled by it at first and then I realized it has a separate compartment on the front end of the crankcase that contains the governor and the mechanism for the injection pump, which are splash lubed by oil in there. The front main bearing may also get its lube from there since the oil pump only has lines to the rear main bearing and the cylinder.
Hereís a short video of it running.
Mike
SmokStak member #146
The Following 3 Users Say Thank You to Junkologist For This Post:
Old 09-07-2018, 11:01:45 AM
rodneyt rodneyt is offline
hi guys,
it sure runs nice now, sounds ready for serious work.
seeing as how the petrol JLO motors were 'design bought' and used on small Wacker-packers,
it would not surprise me if they used these diesels too.
this is where my JLO education began:
http://www.tractorbox.co.uk/forum/fo...ts.asp?TID=120
http://myoldmachine.com/topic/3619-howard-hako/
cheers Rod.
The Following User Says Thank You to rodneyt For This Post:
Runaway 2 cycle diesel video BTurney Vintage Diesel and Oil Engines 9 09-21-2009 04:10:14 PM
Detroit Diesel two cycle in-line engine. Robert Smales Antique Gas Engine Discussion 1 08-28-2008 05:06:58 PM
Diesel 2 cycle Bessemer artrans Oil Field Engines & Related Equipment 1 12-18-2007 09:06:15 PM
Two cycle, four stroke, diesel engine. Gene Fisher Antique Gas Engine Discussion 9 07-04-2007 10:19:51 PM
smallest 4 cycle diesel Jim Hainen Antique Engine Archives 1 01-27-2001 07:11:21 PM
