Rumely 30-60E-restoration help required....
this thread has 2 replies and has been viewed 2082 times
Old 11-25-2011, 07:51:13 PM
jim burlingham jim burlingham is offline
Photo Rumely 30-60E-restoration help required....
I am helping a local collector locate parts to assemble an early Rumely 30-60E. He is down to the last few parts required to finish the project. This tractor, when finished, will be the fourth running 30-60E in Ontario. I would appreciate any assistance locating the following parts......
Valve cages/pots
Left cylinder (part #3141)
Bull pinion gears and shaft
Differential face gears
Early 30-60 manual (#1)
Thanks to everyone in 'STAKland' who has already answered my 'wanted' requests for parts in Enginads section!
Perserverance will eventually pay off.........
Thanks,
Jim Burlingham
St.Marys, Ontario, Canada
P.S. Late November and NO SNOW! Likely just jinxed myself!
Name:	blyth 2009 (3).jpg
Old 11-27-2011, 10:15:18 PM
Photo Re: Rumely 30-60E-restoration help required....
Lots of views with no replies......
Any leads appreciated!
Added a couple pictures to keep the post alive!
Thanks,
Jim
Rumely 'E' and 'F'......
Name:	loading at Charlie's for blyth (75).jpg
ID:	121977   Click image for larger version
Name:	3-blyth 2011 019.jpg
The Following 5 Users Say Thank You to jim burlingham For This Post:
Old 11-27-2011, 11:54:37 PM
Default Re: Rumely 30-60E-restoration help required....
Nice looking E. What's the serial. It must be a 1911. I need an 8 spoke 4 lug master (Bull gear), sliding gear and bull pinions. I'm setting up a wire feed welder for gear teeth. I understand the Toth E from Saskatchewan had new master bull gears after it sold. Right pinion is part of differential sleeve.
I don't have extra parts you need. I do have an extra differential, but it is tentatively promised after I get mine done. Gears are worn.
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines 25 10-22-2013 09:47:29 AM
Rumely Line Drive Restoration KRHough Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 05-12-2011 10:49:34 PM
Rumely X Serial No. Plate Restoration Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 02-11-2011 09:44:03 AM
Rumely Oil Pull restoration questions... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 10-15-2010 06:58:06 AM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
